turbo 5.3 overheating
I have a 93 mustang wit a 2002 5.3 in it, car runs extremely well my problem is I cant keep the car cool. the setup is comp 224/228 cam ls9 headgaskets lifters springs pushrods ls1 waterpump truck manifolds flipped to a 74mm precision turbo. I have tried everything I can think of, it has a 31inch speedway dual pass radiator 3000cfm fan 180 thermostat with two 1/8th inch holes drilled into thermo the steamport is plumed into the radiator right under cap all hotside piping is heat wrapped and also have a turbo blanket. the car wants to run about 215 crusing and after a pull it climbs to about 220 230 and will not recover unless I coast in neutral for a good ways. I am ready to pull my hair out I don't know what else to do any advice is appreciated
I had a cheap griffin ls swap radiator in my nova which I believe is about the same radiator as the speedway radiator. No matter what I did my car would not run any cooler than 210-220 and would creep up into the 230-240 range in traffic. For along time I put it off as the intercooler restricting airflow. One day the radiator sprung a leak and I said to hell with it and bought a $610 Dewitt's radiator. now my car runs 190-195. Doesn't seem to matter what kind of driving I do.
im pretty sure I got all the air out all I know to do is just try it again.
that is very interesting about the difference in temp on those radiators I have a fox rad laying around I may just try for ***** and giggles to see what happens
You want to make sure you jack the nose of the car up a bit, and use a large funnel to burp the system. like so...
As mentioned most likely your radiator is crap. I'd call up howards and have one made to whatever dimensions you need. Also as mentioned the Taurus fan flows about twice the CFM on high (around 6000cfm). I run a good 14x14 radiator and am able to keep the car plenty cool with a taurus fan. My 4.5" thick IC is also blocking it 100%
Somebody asked what it reaches while at idle. This is a significant question because ignition timing can cause "overheating" (the egt will climb to 1500*F+) while cruising if there is not enough advance. You should be cruising at 36-39* btdc timing, with an 14.8-15.0 air fuel ratio. If the engine does not hit 200*F+ at idle, but does while cruising, this is where I would look next (timing).
On the other hand, if you are hitting 200*F+ with fans on, while at idle, you have a cooling problem related to water/fans. mostly fan I would guess. Ducting, a good fan, and a good radiator is next.
