Manual boost controller question
Old 09-20-2016, 03:59 PM
3 window's Avatar
Default Manual boost controller question
I've got a DIY boost controller that consists of a ball and spring. It's plumbed between the intake track (pre throttle plate) and the lower port on the gate. In testing, if I apply shop air to the gate (without the controller) the gate cracks at about 6 psi and is full open at about 12-14 psi. If I install the MBC, each half turn results in the gate cracking 2 psi later (1/2 turn=Cracking at 8 psi, another 1/2= cracking at 10 psi, etc.) but still fully opens at 12-14 psi. I've been running the car at the 6psi cracking position. Could I expect faster spool at the 10 psi cracking position with the same overall boost seeing all settings fully open the gate at 12-14 psi? Hope this makes sense.
Old 09-20-2016, 06:18 PM
Restricted User
JoeNova's Avatar
Yes, it will spool faster. That is the main benefit of the spring in the manual controller.
Old 09-20-2016, 08:53 PM
69-chvl's Avatar
3 window, any reason your not using the boost control function with the Holley? Its just too easy not to!
Quick Reply: Manual boost controller question
