!!!Compound Boost!!!
Old Sep 13, 2016 | 05:33 PM
compted's Avatar
Default !!!Compound Boost!!!
I am taking the long and difficult plunge into compound boosting an LS motor. This for will be an information place for everything I learn and build.
Proof of concept will be on a 4.8l gen 4 ly2 that I am going through to make sure it will live as much as possible
https://ls1tech.com/forums/conversio...onversion.html
http://www.lsxmag.com/news/twin-turb...-national-gnx/
__________________
-Plan
Build a low compression 6.0L
  1. Tune on a 1.9L or 2.3L supercharger
  2. Build turbo kit consisting of turbos off of each manifold and develop a low back pressure setup on the same motor without the supercharger
  3. Install both setups and work out the bugs
Old Sep 13, 2016 | 06:39 PM
jimmyg's Avatar
There is an lsa/ twin turbo gn somewhere in the conversions section
Old Sep 13, 2016 | 07:27 PM
Hi-Po's Avatar
Sounds like a disappointing money pit. It has possibilities of being fun, but a major head ache.
Old Sep 13, 2016 | 07:59 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
If you really want to delve into that sort of money pit and tuning problem, compound turbos will make more power than turbo/SC. Look on Yellowbullet for a very informative(but long) thread on the subject. There is a guy building 50#'s of boost on his 2step at the line with a 1.9L motor, and approaching an ideal 1 to 1 backpressure ratio. His road to that was a rough and winding one.
Old Sep 13, 2016 | 08:47 PM
DavidBoren's Avatar
Forget the top mount supercharger. It will be a restriction to the turbo, as seen when you remove the supercharger from most compound boost cobras. So, how do you do it correctly? Here is my version of correct:
F1 centri blower into an A2A intercooler into an S478 turbo into a Lingenfelter A2W intercooled intake. That is a surefire recipe for head lifting/block splitting boost, if you can build an LS engine that wont spray water or grenade at ~4bar, then you have yourself a successful compound boost LS.
I, personally, wouldn't even consider it a serious attempt without an intercooler between the two separate stages of boost. I would probably still run a four nozzle meth injection system with a nozzle before and after each blower. Compound boost LS should absolutely have 6-bolt heads and either an iron LSX/DART block, or a fully prepped ERL ductile iron sleeved aluminum block.
If you want to see how gearheads build compound boost systems, study up on those Cummings sled pullers. They run centri blowers into single turbo setups with great success.
Old Sep 13, 2016 | 08:53 PM
DavidBoren's Avatar
Remember, with compound boost, your atmosphere blower HAS to be capable of moving ALL the air required to meet your goals.
Old Sep 13, 2016 | 09:46 PM
gametech's Avatar
Your way still leaves the crank taking on the added stress of driving a blower. Realize that this is all theoretical, as the OP obviously has no clue what this entails.
Old Sep 13, 2016 | 09:55 PM
speedtigger's Avatar
Old School Heavy
__________________
-Plan
Hennessey Motorsports does this on the new Hellcats. They have acheived 1000 rwhp if I remember correctly. Also, there is a guy on the conversion section who had done this with an LSA in a Buick Grand National.
Old Sep 13, 2016 | 10:16 PM
DavidBoren's Avatar
If the crankshaft cannot handle the extra 50hp worth of work it takes to spin the blower, then it is not going to survive 45-60 pounds of boost anyways.
This is definitely no small undertaking. Things are going to have to be bulletproof.
I wouldn't consider any combination of parts that resulted in less than a 1.6x rod ratio. That should help the crankshaft survive, as well as reduce side loading of the cylinder walls. The higher rod ratio would also be helping the block survive.
All of this is nothing more than mental masturbation unless the end goal is to surpass what can be accomplished with a conventional turbo(s) setup.
If you wanted something relatively cheap, just to proof the concept, pick up a genIV 4.8, and run a D1SC into a single S366 and see if you can;
A) achieve more boost than the listed maximum for a D1SC blower,
B) achieve more power than a single S366 turbo.
That would be proof of concept, the absolute cheapest way I can image.
Old Sep 14, 2016 | 11:43 AM
cajundragger's Avatar
is the goal crazy high boost or trying to get rid of turbo lag?
IE- are you going to bypass the blower when the turbo makes more boost(flows more mass) than it?
Old Sep 14, 2016 | 11:44 AM
coltboostin's Avatar
Would be 100% easier to do a compound turbo set up IMO
Old Sep 15, 2016 | 08:07 PM
jimmyg's Avatar
Zenvo st1 .ls based roots blower/ turbo. 1104 hp
Old Sep 16, 2016 | 06:07 AM
stevieturbo's Avatar
I dont see why people are thinking it would be difficult ?
And would a valley mounted blower really be a restriction ? It's apparent even shitty intakes allow huge power...so when you can move already pressurised air through...AND around the valley blower, why would it be any real restriction worth worrying about ?
Most blowers have a bypass, so this could be operated to allow air both through and around the blower at higher loads.
And a basic valley mounted blower takes up almost no room, and you could easily forego any blower intercooling given it would only be a low rpm use deal after which the turbos would take over and obviously they would have efficient intercoolers.
Not many details, but here is something ?
Old Sep 20, 2016 | 11:19 PM
compted's Avatar
I personally have worked on sled trucks but my plan is to build a gas powered sled truck that will make nasty street level diesels that sled pull worry that I am going to beat them with my distance scores and still be able to drive the thing. So I'm in search of torque and as much as one can make for as long as I can make it. This will be an aftermarket efi setup with e85 or methanol fueling.
Old Sep 20, 2016 | 11:22 PM
compted's Avatar
This is also a turbo into blower setup!
Old Sep 20, 2016 | 11:34 PM
compted's Avatar
Granatelli Motor Sports - LS Compound Boost Motor - YouTube
This video is what got the gears turning and the 1.9l lsa blower off a buddies ctsv that I got for a cage build.
Old Sep 21, 2016 | 03:47 AM
If torque is what you want...and simplicity, a big Whipple would probably be the easiest option.
Old Sep 21, 2016 | 03:11 PM
gtfoxy's Avatar
Diesels back in the day ran 6 & 8-71's with turbos blowing through them & a few peeps ran turbos on the lightnings back when they first came out: Nothing new.
Matching compressor efficiencies at given pressure ratios is where the problems lie when comparing a roots/whipple + turbo vs compound turbos. Series turbo systems allow a little more flexibility there due to being able to better match the components with one another.
Old Sep 21, 2016 | 03:32 PM
roastin240's Avatar
I have seen multiple examples of this over the years and even helped my buddy do this with a Mazda V6 about 8-10 years ago. I have seen it brought up about 100 times more than it actually is done. It sounds cool when its talked about, and is why it becomes a pipe dream for many and never comes to reality. Most people who want to go fast will just go turbo(s).
