Guys with ls1 pan and stock pickup tube. How many quarts of oil do you run
Old 03-27-2017, 11:55 PM
Sleeperls's Avatar
Default Guys with ls1 pan and stock pickup tube. How many quarts of oil do you run
Did some searching, but get the normal 5
5 **** for non turbo stock stuff. I'd like to hear from you guys, about to fire my junk up and need to poor fluids in.
Old 03-28-2017, 04:49 AM
LS1-IROC's Avatar
I run 6.5qts in mine.
Old 03-28-2017, 09:00 AM
conan's Avatar
6 quarts with the tall (NAPA)1522 oil filter. Oil level is just on top of the full line. F-body oil pan by the way.
Old 03-28-2017, 09:40 AM
willizm's Avatar
6qts here on stock ls1 pan and block. Ran the car hard for 4 years before having the motor taken apart and refreshed. Engine builder said my bearings looked great. Car cuts consistent 1.2 60's and gets some air.
Old 03-28-2017, 10:15 AM
Docrocket1967's Avatar
I put 6 in and check it and go from there.
Old 03-28-2017, 10:16 AM
jmm98LS1's Avatar
Tall truck filter and 7 qts. I'm adding an improved racing baffle this year to try and help oil starvation.
Old 03-28-2017, 10:57 AM
SteenH's Avatar
I use the large filter and probably closer to 7 than 6 as well.
Old 03-28-2017, 11:08 AM
svslow's Avatar
Same here 6.5-7 qts.
Old 03-28-2017, 01:20 PM
lmt0705's Avatar
6.5 here
Old 03-28-2017, 01:25 PM
Forcefed86's Avatar
As many as it takes... If you see your oil pressure drop at the launch add another quart. I've run as much as 8qts on a factory LS1 oil filter to stop the oil oil pickup from uncovering on the launch.
With the engine running I added oil until it started to trickle out of my oil pans turbo drain. At 8qts in the pan... it just started trickling out of my lower turbo drain pictured here.
Here is 6qts in the pan. When you include the filter and a running engine... the level drops a good 2-3 qts.
Old 03-28-2017, 01:45 PM
3 window's Avatar
I've got a CTS-V pan. It calls for 5.5 qts. I run 7 qts to avoid aeration/cavitation plus to make up for the oil the turbo takes up.
Old 03-28-2017, 02:54 PM
rotary1307cc's Avatar
8.5qts
Old 03-28-2017, 02:56 PM
Fbody pan with 2 gallons in it. And running there is easily a qt+ not in the pan
Old 03-28-2017, 03:41 PM
2000WS6TA's Avatar
ive been running 6 but looking at some of the pics i might bump it to 7
Old 03-29-2017, 03:01 AM
Sleeperls's Avatar
I put 6 in it and some in the filter. It's a new gm performance pan, so threads are newer style. I used to get the taller filters for my wife's daily. Did they make a taller filter for the pf48style threads?
Quick Reply: Guys with ls1 pan and stock pickup tube. How many quarts of oil do you run
