Radiator fan for turbo
I didnt exactly know where to put this thread. Has anyone utilized their stock radiator fans as pusher fans with a stand up radiator/turbo setup? I dont know if its a stupid idea or even possible but I was thinking would it be possible to take the fans off and put them on backwards to make them pushers as opposed to puller fans? Right now i have twin derale fans but I lost trust in them last summer on of course the hottest day where I probably shouldnt have even had my car out, the connectors from the ractronix harness to the fans melted and my fans wouldnt work and I was overheating. Those fans draw a ton of current. Plus they are very, very loud. Id love to put quieter more reliable fans (aka stock) back in my car. Just dont know if its possible. Also after storing them for 3 years I threw them out and then my harness melted so Id have to track down some new used ones or buy aftermarket ones. I saw that Rockauto sells just the fan itself which kinda gave me the idea of taking them off and turning them around. Any input?
Guys have done it and said it works okay, if you're in a hot climate or on the edge of keeping cool I wouldn't.
I ran Derale fans on my last car and had similar issues melting stuff.
If you oversize the wiring, use large connectors and self-resetting circuit breakers instead of fuses they work very well.
The cheap China fuses they come with don't hold up to the amp spikes when they turn on.
I don't know what kind of car you have, but the problem with pushers is they need to be powerful enough to blow thru the radiator, where the weaker ones cant, something about static pressures and all that stuff, as it was explained to me. Years ago I had a blown BB in an El Camino, didn't have room for pullers, so I went with two Spal fans, they were the only ones strong enough to work. If you burned up the wiring you either had a bad gnd or needed upgraded relays and wiring. It def gets hot under the hood, really tests the reliability of elect. components.
The following users liked this post:
The BallSS (05-02-2024)
My car would get a little warm in the summer (190-200 degrees) if the AC was running but I usually had the T-tops out, so I didn't use the AC too often.
the "Syclone" Flexalite fans are work horses. Much better than their standard lineup in my experience.
https://flex-a-lite.com/16-inch-sycl...ctric-fan.html
Just thought I'd throw this out there. I used the stupid little thru radiator ties that came with my fan and they did work for however long they did, but still a huge mistake trusting those things.
Last Saturday night they decided to wiggle free destroying the fan and taking out the radiator at the same time. Just managed to get the car back to safety. No engine damage thankfully.
New radiator and fan will be here Monday and I'll weld some tabs on the rad to mount the fan more securely
If you buy the good ones with springs, they tend to provide a little movement for when the radiator expands and contracts keeping the straps from breaking.
Welding on tabs of course is ideal but not everyone has that option.
That sucks but I've never had an issue with these types of mounts.
The BallSS (05-09-2024)
Yea I never had a problem with them before. Maybe I just had them on too tight?? Is that a thing?? Either way I'll be bolting the new fan to the new radiator when it gets here Monday. That 16" Flex a lite fan fits the Griffin radiator top to bottom perfectly so I can easily bolt it on
It didn't damage the radiator fortunately, but the fan was hanging down.
Since I've started using the foam inserts and springs, I haven't had a problem but if you can do mounts then that is of course the best way to go.
I'd also consider adding a second fan to cover as much of the radiator as possible.
I've had them too tight myself, I didn't put the foam inserts or springs in, and the straps broke, my assumption is it was from the core expanding and contracting.
