Need help figuring out how to mount a 10 rib crank pulley
I'm brainstorming putting a procharger on my car. What I'm thinking about doing is (since I'm fabing the brackets anyway) mounting the charger further out (forward) and runing a separate belt. The only thing I can't figure out is how I can get a 10rib pulley mounted up to a ls1 crank pulley. Does anyone make an aftermarket damper with mounts for another pulley?
Thanks
Frank
Thanks
Frank
The 8 ribs are very tight. You're either gonna need custon fans or a way to push the radiator and fans forward(or the engine back). How much boost are you looking to push? The 8 rib SDCE pullies are holding very well. Also have you considered custom 8 rib crank and s/c pulleys? If you increased the size of both proportionally you could maintain the same flow with increased surface area for the belt to grip with. But I guess it depends on if you need that setup? Read up on the SDCE, I haven't yet seen someone hit the ceilling of that setup.
Mike
Mike
I don't have the clearance issues in front of the engine in my car. If it turns into too much of a pain in the rear I'll set it up in line with the stock pullies and use the 8 rib set up. But I was figuring on doing the 10 rib and changing the crank pully size instead of the one on the charger so ( like you were saying) I could get more surface area.
I'm not going to run an insane amount of boost. I was looking at between 15 and 20 after I get a forged short block in there. I want to get the system built and get the bugs worked out before I build a motor.
Thanks
Frank
Thanks
Frank
Probablly an F-1 but I'm not 100% on that yet. That was gonna be my next question.
I don't know what the heck I wann do right now. I'm at a toss up between getting a magnacharger or fabing a procharger kit. I know I will have much more room to grow with the procharger but the magnacharger will be soooo easy and cool looking. I should need to put down about 600hp to run low 10s in my car and that's what my goal is.
I could do it pretty easy now with a good set of heads and good tune, but I want to get away from the nitrous.
LS1Tech Co-Founder
Vortech makes 10 rib blower pulleys for Mustangs, I wonder if they have anything that can be adapted to their LS1 crank pulley setup.
By the way I suggest you either run a Magnacharger or a Vortech.
Get a procharger, I run an F1, its a great blower
15psi no slip
SDCE tensioner
660rwhp through a TH400 on 28" tires, and my converter flashes to 6200, yikes......
A new one is the plan before spring.....
Would be well over 700 with a 6-speed
15psi no slip
SDCE tensioner
Frank
LS1Tech Co-Founder
I think that most of the Eaton-based setups might not hit 600rwhp, I wonder if you can get one that is bigger than the one that most folks use. I think most kits use the 112 or something like that?
Were you planning to run an intercooler too?
I think Vortech stuff is better, we all have our favorites, but a T-Trim can easily make 600rwhp and make over 700rwhp.
Oh, and who was the woman in your car pic in the calender?
Yeah I was gonna run an air to air in front of the radiator, I can get a 14x20x3 core up there. I'm gonna have to look into the vortech stuff. A buddy of mine has a 64 like mine but it's tubbed with a carbed small block kit on it @ 19psi and it runs awsome! I'm not sure which vortech it is though.
She's just a friend.
Frank
Frank
LS1Tech Co-Founder
Hmmm, good price? YSi-Trim is a 1600 cfm blower, and it rated up to 1100 crank HP. You could pulley it down to like 10psi for an easy 600rwhp. I upgraded my blower from YS to YSi, and so far have made 700rwhp at 5000 rpms. I'm pulleyed for 17-18psi, and am running a T400, 9" and slicks.
T-Trim has 3.5 inlet and the YSi-Trim has a 4.0 inlet.
I messed up, he has a ys and is upgrading to a ysi.
I have a question though, when you step up on blower size what does it do with the power curve? The reason I'm asking is cause I want to keep a usable powerband for the street.
I'm an old turbo guy and don't have any experieance with the centrifigals yet. thats why I might be asking dumb questions.
LS1Tech Co-Founder
It costs like a grand to upgrade from YS to YSi.
My old combo made 575rwhp at 5000. I made 746rwhp at 6900. I stepped up the cam, and upgraded to the YSi. YSi upgrade is supposed to be good for 30hp across the board. But with the bigger cam I am also building more cylinder pressure more quickly. I went from 230/236 to 236/246.
LS1Tech Co-Founder
I'd have to do some research, but the 2.85 8 rib I am running might fit Mustangs too, so it's conceivable that the 10 rib stuff might only be difficult when sourcing the crank side.
Stock Vortech kit runs 8.00 crank/3.12 blower, I am running 2.85 blower. There is also a 2.95 blower out there too. I think I'd do like 12 psi with 8.00/3.12, I happen to have a 3.12 pulley around they are not very expensive.
I think 700rwhp on 93 pump with an 8:1 motor (I am 8:1) is doable.
CAPA in Australia do a crank pulley for an LS1 with mounts for a seperate pulley.
see pics of my pulleys, that i'll be using with my YSi which should arrive very soon..
