10# of boost safe on10.9:1 engine??
Old 03-17-2006, 10:47 PM
sandro arellano's Avatar
Default 10# of boost safe on10.9:1 engine??
just as the thread name says, is 10 pounds of boost safe on my 10.9:1 compression engine? has a forged bottom end and is making about 420 rwhp right now. 238/232 cam and 1.5 stage ported heads.
Old 03-17-2006, 10:50 PM
brad8266's Avatar
I wouldnt do it. With the higher CR I would spray it.
Old 03-17-2006, 10:52 PM
any reason why? dangerous for the motor? how about 7#
Old 03-17-2006, 11:06 PM
calongo_SS's Avatar
High compression + boost = detonation = boom
Old 03-17-2006, 11:07 PM
i understand that but i have seen stock motors, which are 10.1:1 running 10 lbs, what could i get away with?
Old 03-17-2006, 11:09 PM
calongo_SS's Avatar
I honestly don't know, I'd guess 5-7 psi w/ a good tune. TTT for ya, maybe someone else will know.
Old 03-17-2006, 11:10 PM
i will also be running the pisc ati kit with the twin intercoolers, dont know if this will help any...
Old 03-18-2006, 12:21 AM
Nine Finger 02 Z28's Avatar
I am currently running 10.5 to 1 with 20#'s of boost with a SBC but this is a track only Car on C 16 Race Gas.Not a Street safe set up though.
Old 03-18-2006, 12:40 AM
so what do you think about 10 pounds on 91 octane?
Old 03-18-2006, 12:41 AM
oh and what the hell does TTT mean?> hehehe
Old 03-18-2006, 12:47 AM
my bottom end is forged for the power and survival of the pistons but would detenation be a big concern>>? or with a good tune is it doable?
what about 7 pounds? is this more fisable?
Old 03-18-2006, 12:48 AM
I would say no.But not impossible would have a lot to do with how well it was tuned and how much total timing that you will be able to run.Also has alot to do with weather conditions because it will run hotter in the summer which would even make it even tougher.
Old 03-18-2006, 12:50 AM
7 pounds?? is this still in the danger zone?
really?? so if i end up getting the ati kit with twin intercoolers the 7 pounds should be ok???
Old 03-18-2006, 12:51 AM
Yes...
Old 03-18-2006, 12:59 AM
calongo_SS's Avatar
You should sell the heads you have, and get some stock or ported 6.0 L heads and then you wouldn't have to worry about it.
Old 03-18-2006, 05:14 AM
smokinHawk's Avatar
use a 110 octane you might get away with it
READ THE STICKIES FELLER
https://ls1tech.com/forums/forced-induction/208864-turbo-faq.html
Old 03-18-2006, 05:32 AM
EPP
EPP's Avatar
Question
What is the cubic inch of your engine? If it is higher than a 346, you may not be able to get much more than 7 psi out of the P-1SC anyway, depending on the cam profile and cubic inch of your engine. You may also have the smaller 3.5" thick twin high flow intercoolers, which won't be as effective at cooler the compressed air as the newer 4.5" twin high flow intercoolers. You could also go with a large front mount intercooler, which would be less expensive than upgrading to the 4.5" twin high flow intercoolers, and will do a great job at keeping the air cool. Keeping the air cool is one of the keys to how much boost you're going to be able to run. Bob
Quick Reply: 10# of boost safe on10.9:1 engine??
