ATI blow off valve
ATI blow off valve
Guys I'm running a 408ci..... F1R@ 15#... using the stock blow off valve that came with the P1SC. Under deceleration I'm blowing my plunbing off my TB. Is the Stock P1SC blow off to small? What are you guys running, what do you reccomend? Any help appreciated.
You have been helped
Get either the Vortech MONDO bypass -OR- An ATI Race Ready Bypass.
A quick internet search of either term will net you a place to buy one.
You will have to change your flange to mount one of these two.
$245@summitracing
$245@summitracing
TECH Cry Baby BOSS APPROVED!
This is the one I am running. And yes it sounds like a big *** portable air compressor leaking lots of air. If you click on the link in my sig you can see a small pic of the bpv.
http://www.exoticperformanceplus.com....html?item=645
SSU'S Vice Mod
Originally Posted by Ping King
you do not want to run a BOV on a blower car....puts a ton of strain on the blower and all youll hear is chirping. and maybe get a crappy idle.
you need a bypass valve.
Originally Posted by sb427f-car
Either system will relieve the pressure and the bypass vs blowoff is more related to the intake tract layout and where the air is "read". It is dependant upon how the whole system is rigged and where his MAF is located. Though, I'd assume that with an F1R, the original poster is not running with a MAF tune and more likely a SD tune. Considering I've seen a hot street camaro with a big block, f3r, and a 4 port fuel system running an ATI-race blowoff valve, I think our friend running an F1R should be fine.
Mike
all of that air has to go somewhere...thats why you cant run a standard BOV on a centrifugal car...you really need to run a ATI or vortech type bypass valve.
the bypass valve is also open at idle...which will allow a smooth idle instead of some surging that can occur.
SSU'S Vice Mod
self... yes yes...brain fart...I was only thinking about the recirculating type as far as meetering goes...appologies.
Buschman...how the hell are you doing, long long time no talk.
