to heads and cam or not, that is the question
Old 04-12-2006, 07:55 PM
GTFORMULA's Avatar
Default to heads and cam or not, that is the question
I bought a 99 frc corvette. Im gettin a twin turbo system that will have twin 44 mm turbos. Will a set "that I already have" of patriot stage 3 2.08 heads and a futral F-4 226-226 / 575-575 on 114+4 make more power relieably on the same 10 pounds of boost than the stock heads and cam. Very simple question, drivablilty is very good with this setup so thats not a problem. What do you guys think ? How much more power if any ? I already know the stock bottom end will be at its max so I will have a very safe tune also.
Old 04-12-2006, 09:12 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
What is your power goal?
Old 04-12-2006, 09:58 PM
LSs1Power's Avatar
Whats your compression?
Old 04-13-2006, 05:17 AM
EPP
EPP's Avatar
Smile
With the twin turbo kit you certainly would make more power with the heads and cam that you mentioned, but I wouldn't advise it on a stock bottom end.
Check out this Corvette that we added twin turbo's to. http://www.exoticperformanceplus.com...Car.php?car=26 Bob
Old 04-13-2006, 08:41 AM
GTFORMULA's Avatar
That is a very good wright up. I have seen this car before and all I can say is Im glad I didnt buy the HP kit.
Compression will be 10.4
I have no power goal what it makes is what it makes. But Im sure it will make 550-600 rwhp.
If it would be safer to run lower boost but have the power of the heads and cam I would probably do it.
Old 04-13-2006, 11:13 AM
LSs1Power's Avatar
Run 8psi and you should be somewhere in your goal range. Good luck
Old 04-13-2006, 01:22 PM
GTFORMULA's Avatar
Any ideas om how much extra power it would make with 8 psi with new heads and cam over stock heads and cam.
Old 04-13-2006, 03:09 PM
LSs1Power's Avatar
I would say 470-500rwhp without the heads and cam and 550-600rwhp with the heads and cam you have.
Old 04-13-2006, 04:25 PM
WS6 #3392's Avatar
LSs1Power how much are you running?
Old 04-13-2006, 04:43 PM
WS-Sick's Avatar
I'd sell the aftermarket heads and cam you have now and put the money towards a forged bottom end. You can keep you stock cam and heads and make plenty of power if setup right. A little porting and a cam swap later on will net more power and you'll not have to worry about the bottom end.
Old 04-13-2006, 05:28 PM
Tiago's Avatar
I made 700 rwhp on stock heads and cam...........
Old 04-13-2006, 08:45 PM
GTFORMULA's Avatar
Thanks for the input. I think Ill be swaping the heads and cam this weekend . I hate working on cars.
Old 04-13-2006, 10:58 PM
markp03's Avatar
might want ot think of a new hobbie if you hate working on cars....by turboing your car you are asking for alot more work.
Old 04-13-2006, 11:17 PM
LSs1Power's Avatar
Im on a stock bottom end which is 10.1 C/R.
Old 04-14-2006, 07:48 AM
GTFORMULA's Avatar
Yes I meant that I dont enjoy working on them anymore. I love to race and go fast so if you dont have a **** load of money then I have no choise but to work on it my self.
Quick Reply: to heads and cam or not, that is the question
