How do I tell if a Turbonetics turbo is P or Q trim?
Old 05-08-2006, 11:28 PM
blackbird345's Avatar
Default How do I tell if a Turbonetics turbo is P or Q trim?
Anyone know the specifications of a p or q trim?
Old 05-08-2006, 11:40 PM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
p trim = 2.542 inducer/2.920 exducer
Q-trim = 2.693 inducer/ 3.111 exducer
Jose
Old 05-09-2006, 12:33 AM
So is a hybrid possible using a turbonetics q trim and a precision turbo?
Old 05-09-2006, 09:12 AM
LS1TECH Sponsor
What parts are you using off both??
Old 05-09-2006, 02:51 PM
I was hoping to find a precision turbo that would fit my q trim .96 AR turbonetics turbine. However, would you be able to tell me whether my turbine housing would bolt on to this turbo
Old 05-09-2006, 06:04 PM
LS1TECH Sponsor
Without part #'s or measurements its impossible to tell. Also if you plan to use a PTE unit it will not work. The GTQ turbine wheel they use will not work with a standard Q-trim. The standard q-trim is known now as the motorsports Q-trim.
Jose
Old 05-09-2006, 10:03 PM
Ok thanks. Do you all happen to sell on center exhaust housings for Precision turbos?
Old 05-09-2006, 10:04 PM
LS1TECH Sponsor
Yes, we have exhaust housings for virtually any brand turbo.
Old 05-10-2006, 12:24 PM
big hole polished side: EXT-104mm INT-98mm
small hole polished side: EXT 63mm INT 53mm
big hole darker side : EXT 92mm INT 70mm
Flange darker side:
flange 105mm x 95mm
Inteaxial bolt holes
top/top and down/down 82mm
sides 70 mm
These are the measurements on the turbo, any chance you would have an Oncenter housing for this?
Quick Reply: How do I tell if a Turbonetics turbo is P or Q trim?
