Oil Feed line question with Pic.
Old 05-28-2006, 07:29 PM
Josh@KY-Turbo's Avatar
Default Oil Feed line question with Pic.
Above is how I ran my oil feed line. Is this correct or was I supposed to Tap directly into the block?
Old 05-28-2006, 07:32 PM
stevieturbo's Avatar
looks fine to me.
Old 05-28-2006, 07:55 PM
MIGHTYMOUSE's Avatar
long as you drilled a hole through it
Old 05-28-2006, 07:57 PM
frcefed98's Avatar
LOL you pm'ed me the same question and you post it here...lookin good and like MM said as long as there is a hole drilled through it you are all good.
J
Old 05-28-2006, 08:04 PM
I drilled the hole through it for sure. Yeah i PM Jer and then post it here and in my build-up thread. OVERKILL. I searched for a pic for a while and decided to start a thread for future searchers.
Old 05-28-2006, 08:45 PM
ou812/z28's Avatar
from that spot u will recive filtered oil to the turbo,,,,,,
Old 05-28-2006, 11:00 PM
code4's Avatar
Do you happen to know the ID of that oil line? Did you use any restrictors in the line? I fabbed up some steel tubing but I wonder if it is too small.
Old 05-28-2006, 11:26 PM
I am using -4 line. My oil line fitting at the turbo has a resrictor in it. I think it's a 1.6mm orifice in the fitting.
Old 05-29-2006, 02:33 AM
Boostaholic's Avatar
That is correct for your feed location, I'm feeding both mine there
Old 05-29-2006, 06:15 AM
98turbls1's Avatar
Where did you get that piece??? I need one for mine..Thanks
Old 05-29-2006, 10:53 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
i see that repsol peeking in the background
Old 05-29-2006, 11:23 AM
What piece are you refering too? The one I drilled and tapped was part of the oil pan.
Yep the Repsol is back there. I have been tossing around the idea of selling it. I dont ride anymore. Its has been sitting on a rear flat for 6 months. I have new tires just havent put them on. PM me if interested.
Old 05-29-2006, 11:32 AM
the peice is bolted to the oil pan
if you drilled /tapped it while it was installed, you should remove it and clean the aluminum shavings from behind it asap.
Old 05-29-2006, 02:41 PM
JMBLOWNWS6's Avatar
Yup I used the steel braided line kit like that from Vortech on mine.
Old 06-05-2006, 03:12 AM
whats the damn torque spec for those two bolts?
Old 06-05-2006, 12:23 PM
99Custom's Avatar
I know on my old mustang i had to tap into the bottom of the oil pan
Old 06-05-2006, 12:47 PM
just use your best judgement, and a 1/4" ratchet
Old 06-05-2006, 01:16 PM
i guess i'll try 106 in-lbs
Old 06-05-2006, 04:43 PM
SINISTER's Avatar
go easy its small like 12 or 8 ft lbs i think
go with mighty 1/4 ratchet and tighten till snug
once again go easy i snapped one off not even thinking was just like la la tighten snap **** tap it out
Old 06-05-2006, 04:45 PM
I hand tightened them until I thought that it was tight enough. No need to try and kill them .
Quick Reply: Oil Feed line question with Pic.
