do i need a restrictor for my oil feed?
Old 07-22-2006, 10:46 PM
markp03's Avatar
Default do i need a restrictor for my oil feed?
hey guys i have a pt76gts i am running a 10an return and a 4an feed and i am getting oil past the seals... what can i use to retricte it>?
Old 07-23-2006, 12:55 AM
Boostaholic's Avatar
How is your oil drain setup?
What have you done to relieve crankcase pressure?
Old 07-23-2006, 01:35 AM
SuperZ's Avatar
either a larger return line or I have a nitrous jet in my feed line for a resrtictor
Old 07-23-2006, 01:48 AM
ls1CANTU's Avatar
i had that same problem and i just ran the breather hose from the pass valve cover to the inlet of the turbo and took care of it.
Old 07-23-2006, 02:05 AM
From what I understand if you have to use a restrictor with that turbo you have other problems
Old 07-23-2006, 09:39 AM
KAOS's Avatar
jose told me that they use restricotrs with about everything. as small as.025 if needed
Old 07-23-2006, 10:40 AM
markp03's Avatar
what size jet should i try? i have a #52 nitrous jet right now.
Old 07-23-2006, 11:03 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
we drilled my n20 jet to .070 and ive got no smoke or oil and i have the same turbo as you
Old 07-23-2006, 12:07 PM
MiaSSmaro98's Avatar
ohh man so a 4an line supplys to much oil to the turbo?
Old 07-23-2006, 03:27 PM
2002/Black/SS's Avatar
can anyone quickly explain the reason u would ever use a restrictor in the oil lines? y wouldnt u just the right size line to begin with? what happens when the turbo gets to much oil?
Old 07-23-2006, 03:46 PM
Senior Member
Country Boy's Avatar
Youd need a restrictor becuase the LS1 has such high oil pressure and the turbo doesnt need that much oil pressure and thats why it will blow oil past the seals. Imports have this problem too. Jose also to me to use one. Im going to start at .060 and go from there.
Old 07-23-2006, 04:24 PM
once again i learn something new,so u use the 4an line but u get nitrous jets as the restrictors correct?wat size though?
Old 07-23-2006, 05:26 PM
Darren P's Avatar
maybe that is my problem
I am running a precision t 67 and a -10 return line that is around 4 inchs long with a PTS kit and it is getting oil into the intake side
but when I asked Jose this same ?? 6 or 8 months ago he said that it was only for the rear mount guys and I should be fine
WTF
Old 07-23-2006, 06:52 PM
Senior Member
Something I found...
IMPORTANT NOTE ABOUT -4AN FITTINGS AND LINES ON T3/T4 TURBOCHARGER INLETS
Please take note that in some cases (inlet oil pressures above 65 psi - like in import engines) the oil seal in the bearing cartridge may blow out and start leaking oil onto the back both the compressor and exhaust turbines. This is due to the higher flow characteristics of the 4AN (1/4" ID) line. The smaller -3AN line (3/16" ID) acts as a restrictor and helps regulate the oil pressure within the turbo bearing cartridge. Purchasing this -4AN flange indicates that you understand this risk and you are willing to deal with any associated problems.
Old 07-23-2006, 06:55 PM
Good find, I know there are people who run unrestricted setups but lots of them also have dry sumps or other things that will help suck oil out.
Sounds like its time for me to get 2 restrictors before throwing the new turbos back on my car.
Old 07-23-2006, 07:00 PM
67Firebird455's Avatar
I have a -4an feed, -10an return on the mocal. I had to run an .050 restriction (got it from function 7 on the net) built into the flange, which I liked, makes it look professional... I am still getting a little bit of oil in the charge though.
Old 07-23-2006, 07:10 PM
Senior Member
Same one I have
Old 07-23-2006, 07:37 PM
Same one I have
Right on brotha man... Seems like we have a lot of the same ideas/decisions... brains must be working on the same frequency or something! How's your project coming along?
Check this...
Weather for my Area
Been working outside and in the garage since 12:30PM today, hot as heck... the stupid thing SHOULD say "Feels like 'HADES'", not 112.
Old 07-23-2006, 07:42 PM
smokinHawk's Avatar
i use a 4an line for the feed, and 10an for the drain. no restrictor
works great no oil smoke.
when i tried one on my tti kit, it killed the turbo.
found out later it was the drain.
look on the drain first.
Old 07-23-2006, 10:46 PM
code4's Avatar
Well now I am doubting my oil feed line. I made a steel 3/16 feed line with a 90 degree 1/8 npt at each end. The 3/16 line is approximately 9/64 inside diameter. I was hoping this would feed just the right amount with a -10 AN return line. Maybe it won't be enough?
Quick Reply: do i need a restrictor for my oil feed?
