Truck manifold peepz q's within...
Old 08-31-2006, 11:54 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,110 Likes on 728 Posts
Default Truck manifold peepz q's within...
Are most of you guys running Taylor heat sleeves?
Old 08-31-2006, 01:01 PM
danimal95's Avatar
i would assumje your asking for your own car????sleeves are not needed there is plenty of clearance around the plugs
Old 08-31-2006, 01:09 PM
ninetres's Avatar
I ordered some DEI from summit for $14 for 8 of them. Great insurance.
Old 08-31-2006, 01:15 PM
NA$TY-TA's Avatar
Im not running truck manifolds as you know John but its nice insurance just in case....
I like mine.... we burned a plug wire on my car...
Kyle
Old 08-31-2006, 01:54 PM
bboyferal's Avatar
I have them but I don't have truck mani's.
Old 08-31-2006, 02:12 PM
smokinHawk's Avatar
im not running a sleeve right now, seems to be doing ok. no signs of melting anywhere.
Old 08-31-2006, 02:18 PM
black_z's Avatar
Its cheap insurance. I would do it.
Old 08-31-2006, 03:27 PM
frcefed98's Avatar
I don't run em, and my wires are great. There is plenty of clearance, plus the stock heatshield that bolts to the manifolds works pretty good. Arent your truck manifolds coated as well?
J
Old 08-31-2006, 03:29 PM
Navy David SS's Avatar
Yep. Truck headers. My coil packs are re-located to under the dash, and without the sleeves they would be setting on the headers. Work great. No problems.
David
Old 08-31-2006, 04:00 PM
JRL96TA's Avatar
Make sure you check the heat ratings on the sleeve's. Usually the cheap ones are only rated to 500degrees.
Old 08-31-2006, 05:10 PM
LS1Tech Co-Founder
My hotsides all have black hi-temp coating. I don't believe in relocating the coils, I like them in the stock location. It's an awesome setup and one of my favorite aspects of the LSx series.
Old 08-31-2006, 06:10 PM
ninetres's Avatar
What kind of high temp coating is functional (like equal to wrapping them)?
Old 08-31-2006, 06:27 PM
black_z's Avatar
HOw well will powdercoat hold up on the truck manifolds for a turbo setup?
Old 08-31-2006, 06:59 PM
frcefed98's Avatar
Its not a powdercoating. Its thermal coating, BIG difference. I'm sure John went with a thermal retention coating on all hot side pipes.
The black thermal coating should be good up to 2k degrees.
J
Old 08-31-2006, 07:10 PM
ninetres's Avatar
J
IS it as effective as a header wrap? What if I use both
Old 08-31-2006, 10:25 PM
LS1Tech Co-Founder
Black thermal coating yes.
Old 09-01-2006, 07:41 AM
smokinHawk's Avatar
on my silver ceramic coating i had on my tti kit it would reduce the surface temperature by 100*F (measured)
