F1 Procharger
there is a member here named djs99ss that has done a 408 with a F1 you may want to try to get a hold of him, I think they made it fit by moving the lower radiator up a little bit and the only problem being able to stick the right air filter on there.
the F1 is the same size as the D1.....but if u really want to make some power, step up to the F1C or F1R. these are bigger units, but can still be fit on an fbody. youll have to move u rad forward a little bit, and you wont be able to use the D1's intake elbow. many just use some steel mesh screen. from personal experienve, an F1C ona built 346 is a crazy, violent ride.
TOP VIEW
TILT YOUR HEAD...
DO NOT DO THIS...WILL COLLAPSE ON ITSELF UNDER BOOST! DON'T ASK ME HOW I KNOW
I DON'T RECOMMEND THIS EXCEPT MAYBE FOR TRACK DAYS...
I'm running a 4" aluminum 90. $25 at PepBoys. Had to notch the rad support and tilt her forward, also had to raise the condenser 1" by extending the tabs. Looks great ... zero restriction... running a 4" aircleaner as well... twice the size of the stock ATI in lenth, and of course 4 "
Restricted User
It'll be an F1R sorry, i didnt post that. We're dealing with a race car so it doesnt have a/c or anything else so i think we should be ok after the radiator support mods. Thanks for the pictures as well...
LS1Tech Sponsor
