Scavenger pump options
Old 09-13-2006, 12:16 PM
FUroundeye's Avatar
Default Scavenger pump options
I've determined that it's going to be much easier to place a pair of turbos in a location that's at/below the level of the oil pan (which I was trying to avoid), so now I'm looking for suggestions/opinions on scavenger pumps. I've done a search and the Mocal is the only one I've seen used/suggested, but I've also read it can be pretty noisy. Are there any other options out there, and if so where can you buy them? I'm having a hard time finding a place just to buy the Mocal unit... Also, any advice as to why it would be a horrible terrible no good very bad idea to use a scavenger pump is welcome
Old 09-13-2006, 12:38 PM
SINISTER's Avatar
i just hooked one up..had an issue with it smoaking but i made a oil resivore box thats under the turbo that pulled the oil from there and back into the pan and worked great no more smoke....
in all honestly i would love to just used gravity.. but when my setup was made i made it so i wouldent have to cut my rad support for the t76 turbo and when i wanted to go to a bigger turbo all i would have to do is snip the rad support move rad forward and id have al the rookm in the world.
as long as you have a way for the oil to collect and not gett pulled fast to eliminate the oil from foaming..
alot of people use them
companys
tilton im useing that just cause it was free
waldon hear good things about this believe its the same thing on a c5 corvette diff and can be gotten cheeper through gm..
mocal is another one.
Old 09-13-2006, 12:42 PM
WestSide's Avatar
There's a company here in Austin where I got my pump from. It's makes some noise but nothing you can hear from inside the cab. They even made the reservoir for it. I bought the needed fittings at austin performance too. The pump is a pricey unit though.
Old 09-13-2006, 02:33 PM
Mike 01WS6's Avatar
You can get the mocal/tilton fluid pump from Racer Parts Wholesale. They are based in Indianapolis, and can take orders online or over the phone. They retail for about 179.99.
They also carry a rebuild kit for it thats about 49.95. This solves the imfamous "smoking turbos syndrom" that occurs when the seals go bad in the pumps. Much better than buying a whole new pump, or having to upgrade to a $500 weldon.
Old 09-13-2006, 03:15 PM
SINISTER's Avatar
cool thanks for the info...mine was smoaking and the pump was brand new clearned up soon as i ran the oil into a reserve tank, and then up into the pump rather then direclt from the turbo..i believe summit also sells the tilton pump
Old 09-13-2006, 03:29 PM
Outlaw's Avatar
So does anyone have pictures of what they are using for a reserve tank? would like to see them if possiable... thanks
Old 09-13-2006, 04:01 PM
Ping King's Avatar
i have my system apart now, but my folks have the camera in florida...imagine...an exhaust pipe with washers welded on the end....there you go hahah.
Old 09-13-2006, 04:58 PM
WestSide's Avatar
Aluminum rectangular box
Old 09-13-2006, 05:33 PM
FUroundeye's Avatar
****, that's small, I was expecting something larger. Shouldn't be a problem at all to fit that in there.
Old 09-13-2006, 09:35 PM
SINISTER's Avatar
mine quite a bit larger but i made it that cause i wanted it bigger
ill get pics as soon as i can
Old 09-14-2006, 06:49 PM
JAvenger007's Avatar
Summit sells the tilton pumps for same price. They look pretty much identical.
Old 09-14-2006, 09:24 PM
FUroundeye's Avatar
So the Mocal and Tilton units are one in the same, just w/ different brand names?
Old 09-14-2006, 10:07 PM
NTSOS's Avatar
This one looks kind of interesting!
Electric Oil Scavenge Pump
John
Old 09-14-2006, 10:59 PM
Not entirely sure. I noticed the tilton mentioned variable pump speed according to engine speed.
Old 09-14-2006, 11:34 PM
MyGoatBites's Avatar
I am using a tilton. Summit has it for $175
Old 09-15-2006, 12:14 PM
lo_jack's Avatar
John
I encountered that one in a search a while back. I agree it is interesting, but I have never heard of anyone using it. It looks like it should work fine though.
Old 09-15-2006, 12:25 PM
WestSide's Avatar
John
That is the unit I am running. So far so good.
Old 09-15-2006, 12:33 PM
FUroundeye's Avatar
I noticed it said it has a 3/8" NPT inlet, so are you using a -10 AN (or 5/8" NPT) drain out of the turbo and into the collector, then a 3/8" NPT out of the collector and into the pump?
Old 09-15-2006, 12:40 PM
WestSide's Avatar
yes, but im using 3/8" ID hose between the res and pump, and from the pump to valve cover
Old 09-15-2006, 01:26 PM
NTSOS's Avatar
Can you hear it running at engine idle?
Thanks!
John
Quick Reply: Scavenger pump options
