Max power out of T76??
Old 10-12-2006, 11:13 AM
TINKRD's Avatar
Default Max power out of T76??
people with these setups, can you let me know what power your making?
my setup will consist of 6.0L block, ported 317 heads, (either truck manifolds or OhioFI manifolds)
i'm looking to make 750-800 on pump gas.
A guy i'm working with thinks that w/ the displacement (364ci) that i'll max it out on higher boost. He advised to look into possibly a T-88.
Any suggestions?
this will be a street/track car.
Old 10-12-2006, 12:49 PM
SSilverSSurfer's Avatar
PT76GTQ=975
PT76GTS=1100
76GTS w/ 80mm upgrade=1200
GT-42 74T=1100
GT-42 76T=1200
Old 10-12-2006, 01:48 PM
TINKRD's Avatar
anyone have dyno sheets running a 76?
Old 10-12-2006, 04:20 PM
99SS-T's Avatar
Mine is a 76 but its a GTS. So it is a little different then what u got.
That is at 12 psi on the stock short block. That aint the 661 rwhp one as i dunno where the hell that is. GL man
John
Old 10-13-2006, 06:34 AM
single digit dreamer
parish8's Avatar
best i could do on with a camed 6.0 and t76 was 640rwhp. thats thru a 4l80 and a tcase and i was running good gas. i saw good gains to about 14psi and then just hot air with more boost after that.
Old 10-13-2006, 01:15 PM
engineermike's Avatar
That's odd. With the T76GTS and 388 cid, I see huge gains when I go from 14 psi up to 20 psi. Been way over 640 rwhp also.
Mike
Old 10-13-2006, 03:46 PM
parish8's Avatar
Mike
maybe that is the gts part kicking in. seems like the t76 is rated at 900? and the gts76 is rated at 1100?
Old 10-13-2006, 03:58 PM
30th t/a's Avatar
whats the fastest spooling of all the T76's?
Old 10-13-2006, 04:21 PM
Probably the one that makes the least amount of power.
Quick Reply: Max power out of T76??
