LS7 heads and intake vs. Dart heads and LS6 intake
I was thinking about buying a set of dart heads and a ls6 intake for my 370ci turbo motor. I been reading on the ls7 heads and intake what would be better? Im gonna be running at least a PT_88 or 91 and im looking for around 1000 at the rear wheels. I hear the ls7 heads flow very well with bigger valves only the 6.0 blocks can use.
Does the LS7 heads have a thicker deck like the ET, AFR, DART,AllPro heads? That is one of the main reasons that people use them. Obviously for the power gains but th4e thicker deck allows for more pressure. Also what is the price on the LS7 heads? GL man
John
John
Originally Posted by Camaro_Zach
ls7 heads do not go on a 4" bore. if you have a 370, you have a 6L block, with 4.030 (or so) bore.
