turning 6.0ltr manifolds upside down?
Old 11-02-2006, 04:55 PM
1FST99Z's Avatar
Default turning 6.0ltr manifolds upside down?
just as the thread says. I typed that in the search button but it said nothing found. would that work. has anyone tried that. just a thought. b/c I want to keep ac but have a nice kit as well.
thanks.
Old 11-02-2006, 04:56 PM
mahhddgtp's Avatar
There is a thread about this somewhere.. Searches can be a bitch. Think they concluded that it wouldn't work, or someone tried it and said it wouldn't work.
Old 11-02-2006, 04:58 PM
1FST99Z's Avatar
thanks
Rock_Daddy's Avatar
Look at the scond fastest car in the 2006 boosted list.
https://netfiles.uiuc.edu/nbrinkw2/B...boosted_06.htm
Old 11-02-2006, 05:03 PM
psifreak's Avatar
look in the stickys.. i just learned about it
Old 11-02-2006, 05:04 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Looking at this construction pic of my car, I'm thinking that it would negate the need to relocate the alternator but would it make it hard to run intercooler piping?
http://psj.ls1tech.com/gallery/main....&g2_itemId=253
1FST99Z's Avatar
I believe those are facing forward. I am thinking about turning them upside down so that the exhaust is routed up and not down or forward.
thanks
Old 11-02-2006, 05:07 PM
1FST99Z's Avatar
you have a point, one thing I need to mention I have the VFN 4inch cowl hood. maybe that would give me more room. I dunno I think I will get a set and start seeing what I can come up with. at least maybe just keep the drivers side one and then having someone fab up a passenger side manifold or use a stock manifold the correct way and having somesort of crossover pipe. so many decisions.
Old 11-02-2006, 05:13 PM
LS1Tech Co-Founder
The Truck Manifold Sticky has a ton of pics, should help you figure out what you want to do.
Someone is selling a custom LSx turbo kit on www.motownmuscle.com right now, it was made for an RX7. It has the upswept header design you are talking about. The kit is on page 2 of their classifieds.
Old 11-02-2006, 06:02 PM
frcefed98's Avatar
Truck manifolds flipped upside down will hit the shock towers on the LS1 F body.
Only one way to run em, backwards and without a/c...
J
Old 11-02-2006, 06:22 PM
smokinHawk's Avatar
J
yup that was one of the first things i tried when i got mine, upside down and forward, they wouldnt fit cause they hit the shock towers, i suppose if you did some clearancing alot of it, then maybe.
and they wont fit running backwards (pointing to the back) cause they hit the firewall.
Old 11-02-2006, 06:25 PM
1FST99Z's Avatar
well I guess it is back to the drawing board then.
thanks for all your help
Wesley
Quick Reply: turning 6.0ltr manifolds upside down?
