Spinning tires at 1-2 shift with STS
Old 11-24-2006, 09:00 PM
LastBlack02SS's Avatar
Default Spinning tires at 1-2 shift with STS
So, I have the mods in sig. I'm on a stock 10bolt with a built 4l65e and street tires. I also have the eboost 2 boost controller. The car is scarily spinning tires at WOT at the 1 - 2 shift and the car wants to go sideways and fast. I was wandering what the best things for me to do now are. I'd like to not have to buy a rear end right now (I'm saving up for it), especially since this car will not see the track more than 1 or 2 times ever. Can I get away with drag radials on the 10 bolt with a stock stall, or am I on borrowed time looking to snap it? I don't do hard launches or anything like that. Also, I have the Eboost2 which i can program per RPM and Gear. I don't know yet how to do it and how to set it up like that, but is this something I should be doing and can anyone help me out with that? I guess lastly, are there any little things I'm forgetting to do on the car? You can check out my other thread with my dyno sheet on this forums. Thanks ahead of time.
Old 11-24-2006, 09:11 PM
navymitch12's Avatar
well either crank he boost down and little between shifts or let off the gas a little after the shift.......or just do what i do and roast them and have fun!!!!!!!!!
Old 11-24-2006, 09:54 PM
SSilverSSurfer's Avatar
gradually ease into the gas, rather than just punch it, be safe
Old 11-24-2006, 10:09 PM
96silverram's Avatar
If you have an E-boost 2 you can definitely help your situation out. I would suggest you read that EB2 manual and set each gear for a desired boost level on street tires. If you run drag radials it will help alot, but your probably gonna blowup the stock 10 bolt at some point no matter how careful you are with the rearend. Remember, 10 botls = glass house
Have fun with your new STS kit
Old 11-24-2006, 11:10 PM
BrandonDrecksage's Avatar
your on borrowed time STOCK with the 10bolt. crank the boost down for 1st and second, rais eit in 3rd, or get drag radials and hope you don't break, unless you can afford it.
Old 11-24-2006, 11:16 PM
FUroundeye's Avatar
What sort of tires do you have on there now/how old are they? I think that's the problem more than anything. I have some cheapo tires on my Camaro now that were on it when I bought it, and I've had to get out of it more than once on the 1-2 shift b/c the car tried to jump sideways. And my car is currently bone stock... I'd say get some decent tires on there first and see what it does for ya. If you don't do hard launches from a stop on drag radials they really shouldn't put too much more stress on the rear.
Old 11-25-2006, 12:57 AM
good thing your auto or that rear would have been toast long ago, be careful though 10bolts are known to go "KABOOM" without warning
Old 11-25-2006, 04:27 AM
They are 285 KDW's and they are at least half tread life left on them. Regarding the Eboost2, does anyone know how to hook it up to the computer on the camaro? They don't provide a wiring schematic for the camaro in the manual. What DR's would you guys recommend to help out with the traction a bit but not too much to kill my rear?
Old 11-25-2006, 08:51 AM
what do you need to tap into on the ecu?
Old 11-25-2006, 09:40 AM
MIGHTYMOUSE's Avatar
275/40 17 mt street radials.
that is the answer.
Old 11-25-2006, 10:45 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
the only wire u need to tap into the computer is so the Eboost 2 will read rpm.
Old 11-25-2006, 03:26 PM
RW99's Avatar
1. Re-discover "part throttle"
2. You're only going to be able to reduce boost down to the wastegate spring limit... so if you want to customize some low boost settings you're going to need to have a spring at the minimum boost you want to run. The eBoost can help you dial up the boost from there (just how far, I'm not sure).
Old 11-25-2006, 08:26 PM
The Red WS.6's Avatar
rw99 and silver surfer first. Then break the rear-end, and upgrade it. As I always say, "it's not a matter of money, just a matter of time".
Old 01-18-2007, 04:54 PM
pdanrichey's Avatar
I have an M6 so I'm probably really screwed! I'm going to granny shift and also engage the rear-end by pushing down the gas pedal slightly (to let it grab), then go WOT. 1st and 2nd will be at PT b/c of no traction...3rd and 4th...bring it on!!...of course using my method above. DAMN YOU GM!!!
Old 01-18-2007, 06:30 PM
Blackbird's Avatar
drag radials make a huge diff, at least they did for me.
Old 01-18-2007, 07:32 PM
Schantin's Avatar
You'd be suprised. 5K launch on DR's....and the stock 10-bolt is still good. Actually blew the clutch first. Anyhow, DR's + constant launch and you will f' the rear up. Like others have said, more when than if. I'm running Kumho's on the street and just live with the fact aht I'll blow the rubber off the wheels. I have 18x9.5's though, so there's a bit more contact patch (probably not spinning as bad as you are.)
I took a couple "cheap" steps to add a bit of life to the stock rear. TA rear cover & ARP carrier studs. I was suprised that the carrier had "shifted" a bit when I put the studs in last year 4K miles later it's still ok. I definetly wouldn't put more $$ than that into the stocker, though.
Have fun with the STS.
Old 01-18-2007, 08:25 PM
great421's Avatar
Yeah, if you had a M6 you'd have broke it long ago - I broke two Naturally Aspirated! One stock, one built by DTS; just say no to 10 bolts!
Old 01-18-2007, 08:44 PM
2001WS6Vert's Avatar
Stock 10 bolt here. I've had Nittos, M/T's and soon 315/35/17 Goodyear SS drag radials.
Old 01-19-2007, 12:37 PM
pdanrichey's Avatar
Seeing more people with the 10 bolt running pretty good numbers gives me a little more faith in it. Ya, many people like you great421 have their horror stories, but with many people I've personally spoken with still have the 10 bolt r-end and have had a great deal of success with it.
If mine were going to break, it probably would have been at the track last time when they actually prepped the lanes and I ran an 1.9 sec 60' time on street tires. At that point, that was the fastest my car has ever felt... I know, not saying much...but still, it was good for me .
One guy at a performance shop told me that he had run the stock 10 bolt on drag-radials with many many N2O runs and never had any issues. The car now has over 100k miles on it and still runs like a champ. According to him, the secret is to not change out the 3.42 gears...apparently, they're stronger with the 10 bolt than the aftermarket gears you can buy.
Old 01-19-2007, 01:01 PM
99Z28LS1's Avatar
i have a M6 on my STS and my car makes over 500 and its still doing fine. but i NEVER do any dig races because i know it'll crumble. my races are done from a roll where the turbo loves to come alive at. plus my cam loves rolls anyways so i do what the car's good at. PS im also on 9.5 MT ET Streets in the back, you'll be fine on the 10 bolt as long as you dont do too many dig races
goodluck and enjoy the STS
Quick Reply: Spinning tires at 1-2 shift with STS
