another is this a good turbo cam thread?
i've contacted a sponsor or two and none of them would give me any recommendations untill i paid for a cam upfront.
i have access to this cam cheap, it was in a buddy turbo trailblazer that made 585HP through an auto, 16 degrees and 9lbs of boost
any thoughts?
when it comes to turbo cam applications, i have no clue what to look for other then a higher lsa.
226/232 569/574 114+2
setup will be a 414ci, GT47-88, 8:1 compression
any thoughts?
Are you trying to save money? What does he want for the cam? How much is a new cam from the places you called? What is your HP or ET goal?
my goal for HP is to be at 900-1000HP on high boost, probably 20-24lbs
nothing too crazy for ET. i hope to run low 9's.
I dont expect the cam to drive like stock. the car will be on a 3 bar SD tune.
Static compression will be 8:1. I will be using 72cc heads (6.0 heads), stock thinckness gaskets ( i believe those are .055) and the the appropiate dished pistons.( i believe -15cc, maybe a little more)
Bore will be 4.060 and stroke will be 4.00.
carb style intake, 90mm TB
LS1Tech Co-Founder
Originally Posted by TINKRD
nope not trying to save money. I want the right cam for my combo. my goal for HP is to be at 900-1000HP on high boost, probably 20-24lbs nothing too crazy for ET. i hope to run low 9's. I dont expect the cam to drive like stock. the car will be on a 3 bar SD tune. Static compression will be 8:1. I will be using 72cc heads (6.0 heads), stock thinckness gaskets ( i believe those are .055) and the the appropiate dished pistons.( i believe -15cc, maybe a little more)Bore will be 4.060 and stroke will be 4.00. carb style intake, 90mm TB
So to be honest, that cam you mentioned would probably be fine. Maybe you should order the cam from him.
Jim from Speed Inc. spec'd my cam this time around. It's something like a 234/234//114. It's lopey and the car made 867rwhp on 24psi with everything you mentioned except with an LS2 intake and a 348ci engine.
i've contacted Jon from Speed Inc, but he's the one who told me that i'd have to pay before speaking to Jim about specs.
not bashing them, i understand the reasoning.
