Anyone still with QMP turbo kit?
Old 12-25-2006, 07:02 PM
Fiery Features Director
Zangel's Avatar
Default Anyone still with QMP turbo kit?
I'm just curious if anyone is still running the QMP turbo kit. I've been having problems with the manifold cracking (rewelded 3 times), so Brian gave me an OFI turbo kit for Christmas. We are going to try to fix the QMP turbo kit one more time to put on the Mustang project. I would like to know if there is anyone running this kit, what did you do to keep the manifold from cracking?
Old 12-25-2006, 07:13 PM
JustAnIlluzion's Avatar
is there a bracket to support the turbos weight ?
Old 12-25-2006, 07:33 PM
black98ws6ta's Avatar
I dont think it is a issue of turbo support, as I have braced the turbo on a kit before and it still cracked back in that area. From what I remember, didnt you guys build a brace for yours too?
Old 12-25-2006, 07:34 PM
Zangel's Avatar
Brian built a bracket but unfortunately it didn't really help. We had problems with the manifold cracking in several locations, mainly the rear primary at the header flange and at the log.
Old 12-25-2006, 07:47 PM
Y2K Pewter SS's Avatar
A friend of mine had the QMP kit, and has had nothing but problems with it. Cracked and re-welded several times among other problems. I believe when he took it down to LG earlier this year they scrapped the entire turbo and went with a bigger turbo and new manifold though. He has poured more money into that turbo from QMP trying to make it work correctly and never been successful. I am sure if he could go back in time he would change his decision to have bought the QMP turbo in the first place
Old 12-25-2006, 08:21 PM
SSilverSSurfer's Avatar
what type of material is it made of?
Old 12-25-2006, 08:25 PM
Zangel's Avatar
304 Stainless
Old 12-26-2006, 08:43 AM
smokinHawk's Avatar
think you could fit a slip joint in there?
Old 12-26-2006, 02:09 PM
I wouldnt think so, the plug wire barely clears the log manifold now.
Old 12-26-2006, 03:03 PM
Brains's Avatar
The primary is curved all the way to the log, so it'd be nearly impossible to get a slip coupler in there. With enough work anything is possible I suppose
Old 12-26-2006, 06:19 PM
Got Me SOM's Avatar
think you need a cast iron manifold.
Old 12-26-2006, 07:35 PM
TT-TECH Veteran
Inspector12's Avatar
Material is part of the of the problem and also the gauge material used IMO. The TTI kit is very similar with out the cracking issues that I have herd of from the QMP kits.
Old 12-26-2006, 10:22 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Maybe OFI could make you a replacement manifold?
Old 12-26-2006, 11:05 PM
maddboost's Avatar
What gauge tubing do they use on the QMP kit?
Old 12-27-2006, 11:06 AM
smokinHawk's Avatar
ya i know its short and curved (had a similar tti kit that would crack)
but if you could fit a small slip joint and do some cuting and welding and some creativity.
another option might be to use a thicker primary tube, maybe some schudel piping.
Old 12-27-2006, 11:40 AM
1INSANEGTO's Avatar
here is yalls fix after a researh because i was bored at work.
You need to drill a hole on each side of the crack. this will stop the crack from growing anymore. Grind to create a bevel to make sure you have a full pen weld.
Weld with 308L wire if its 304 to 304 mat
If its 304 to carbon incoenl 82 wire.
I am pretty sure that will solve everyones issues because welds do not crack on the heat effected zone for no reason. I am sure the cracking was due not the correct wire or mat issues.
O and brains if you need some wire I might be able to get you a few peices
Old 12-27-2006, 02:21 PM
i thought you swapped hot parts already with the OFI parts?
Old 12-27-2006, 02:55 PM
Brains's Avatar
That's the plan... OFI parts are sitting in the box just waiting to be swapped onto Tiff's Camaro... But the old log style will probably make its way onto my LS1 Mustang
Old 12-27-2006, 04:05 PM
1INSANEGTO's Avatar
So uh others that were welding these again what wire did you use?
Old 12-27-2006, 11:57 PM
Restricted User
NOSjohn's Avatar
As INSANEgto stated, to properly fix a weldment that is cracked, it must be ground down or routed past the current crack. This can be done with a simple 4.5" grinder, speed wheel or other methods. The KEY here is to get rid of the entire crack.
The material is also an issue IMO. Stainless is good if properly used. However, in this situation, the design suffers.
If you want to continue to use this piece, grind out the length of the crack, make a root pass, then a cover pass to allow ample material penetration. Then, have a few gussets made and tack them on in a few appropriate spots to reinforce the thin metal. In this scenario, I would put a gusset on the other side of the crack...if it will still allow the "log manifold" header to fit within the confines of the engine bay.
