My Buildup thread 87 rx7/turbo 5.3/th400/8.8 etc
Old 12-31-2006, 04:27 PM
tirefryin_s10's Avatar
Default My Buildup thread 87 rx7/turbo 5.3/th400/8.8 etc
Well here are some shots of my new build the car is basically getting a complete do - over which includes complete new powertrain front to back soild diff/th400/turbo 5.3/full cage/diet/new gauges et
let me know what you think or if you have any questions etc
Motor:
04 5.3L 28000kms
317 6.0L heads with some home porting and 918 springs/ti retainers
ARP rod bolts
comp MONSTER 54-428-11 228/230 .571/.573
comp hardened 7.4 pushrods
ls1 car intake
ported tb
60lb motoron injectors (still need)
Pan tapped for -10an turbo oil return line
Truck water pump with rotated rad hose inlet and such
oil feed for turbo/oil pressure gauge sender
Fuel system:
Aeromotive A1000 fuel pump
Aeromotive 13101 Boost ref Reg
Stock fuel rails
aluminum fuel cell
-08an feed
-06an return
New gauges:
all electric auto meter ultra lites
water
oil pressure
fuel level(where one of the 2 water temps are in pic)
Volts
160mph Speedo
And now for the fun part
Power adder:
custom homebuilt turbo system
Turbonetics Ball bearing T76 turbo with .81a/r
Truck manifolds flipped and ported
2.5" cross over pipe
FMIC
Water meth
3.5" downpipe
Transmission:
Rebuilt Th400
TCI reverse manual valvebody
TCI 3800 rpm converter
B&M Deep cast aluminum pan
Differential:
Ford 8.8
31 spline spool
3.27 gears
moser axles
C clip eliminators
Disk brakes
Girdle
Suspension:
Front-stock with new struts/springs
no sway bar
Rear-Grannys solid axle conversion
New shocks and struts
Wheels/tires:
Weld Racing Pro stars
15x4 with 165r15 skinnys
15x8 with 26x10.50 slicks
Goals for 07 are : 10.50/135mph and 600rwhp -im not sure if i will touch any of those but im gonna damn well try
here is a cool photoshop my buddy had made of my car gives an idea how the new wheels will look except a bit smaller ahah
Old 12-31-2006, 05:03 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
that little car is going to fly
Old 12-31-2006, 05:12 PM
Got Me SOM's Avatar
looks pretty bad azz
Old 12-31-2006, 07:30 PM
HydroStream6's Avatar
Would LOVE to see pics of the rear end setup... my buddy has an FC with an LS1 and we've been contemplating a 8.8
Old 12-31-2006, 08:16 PM
go onto www.engineswaps.com and scroll down to the 2nd gen conversion parts and its in there the solid diff kit
Old 01-03-2007, 01:59 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Looks like it's going to be one hell of a ride. Keep us updated.
Old 01-03-2007, 02:37 AM
99Z28LS1's Avatar
looks like a sweet *** build, that little thing is gonna fly.....
have you put wings on it yet?
+1
Old 01-03-2007, 10:06 AM
started working on the th400 yesterday got it cleaned up pulled out the bolt in yoke painted the case got the B&M deep aluminum pan for it and my converter /reverse pattern manual valve body are on order
Old 01-05-2007, 08:55 AM
Black X's Avatar
Looking good bro!
Old 01-05-2007, 03:25 PM
96 Comp T/A's Avatar
FWIW, I mocked up truck manifolds with my Granny's kit before I pulled it apart to sell the whole thing. You will need to offset the motor over to the driver's side of the car. The header wouldn't go on without removing one of the flange studs, and even then making the turn out of there is going to be fun. An inch or so would probably do you right.
Old 01-05-2007, 06:22 PM
yep found that out last night im sure i can get around it no prob if not ill notch it a small amount for clearance and box it back in
Old 01-06-2007, 02:07 PM
here are a few pics from the test fit , the deep pan etc isnt on the trans yet .... and im unsure what im doing water pump/acc drive wise yet either
Old 01-07-2007, 12:18 AM
Sweet71's Avatar
Hell Ya Bro this summer is gonna rock... Lookin Good!
Old 01-12-2007, 12:58 PM
well here is a few updated pics :box: ...... took 65lbs of wiring out and will put back in about 10-15 everything will work except the power antenna (never worked anyway) the vette covers will be modified.... and some mock up of the truck manifold turbo build .... 3.5" downpipe .... i think i will have all the hot parts coated when done im not sure yet :dontknow:
Old 02-11-2007, 01:36 AM
Fuzzylogic's Avatar
Oooooh, pooorn...
I have never liked the RX7s of that generation (SORRY!), but yours is just evil. I want.
Quick Reply: My Buildup thread 87 rx7/turbo 5.3/th400/8.8 etc
