why does the gt 2-3 cam seem to make such good F.I. power when it seems so mild?
ive been looking pretty hard at a lot of threads for a cam for my new buildup and I cant believe the power people are getting on this lingenfelter grind .571/.578 .207/.220 on 118.5 cl. there are several people over 700 on a 346 with 14 psi and a d1sc!!! Is it because it probably has next to nothing for overlap? does it make a lot of power in the 3000 to 5000 range? it seems like it might not be worth sacrificing drivability to go with a huge bumpstick. how much more power could I make going to a more agressive profile? (if you have examples, id like to hear them) I will have a forged bottom end, 9.0-9.5 compression,( what do you guys like for compression?) patriot lq9 stage 2 heads, meth injection, and a d1sc with 14-16 psi.
7 Second Club
Originally Posted by cablebandit
i doubt enuff gain to justify the cost. Follow what KP has done with the D1sc....on a z06 cam and running well into the 9s...low 6s in the 1/8. Make sure you have whatever EPP recommends for a filter and intake hat etc
7 Second Club
boost in some cases can cover up a lack of a cam and heads.... the reason cams are so important on NA motors is because they try to make the heads and cylinders create a vacuum that sucks air in...... on boosted motors the air is waiting for the slightest crack so it can jam in there... just a thought..
Senior Member
Originally Posted by Hennytime
huh, i didnt know it worked well with a turbo, i thought it just did good with a blower, always learning...
Check out my dyno is the dyno forum I like how it carries the power and doesnt look like a mountain peak.
i really could care less about peak power for the street, the numbers Ive seen have been terriffic under the curve. do you have any recommendations? Im very open to suggestions. Id also like to have a little lope in the idle, so maybe a step up in duration and a tighter lsa is in order for me
There are many advantages to a cam like the one listed above.
1) The lift is reasonable (valve control is hard enough under big boost, milder lift makes it easier on the springs and lifters) this will equal long life
2) Traditional split with the exhaust duration listed above helps get the charge out without pushing it past the exhaust valve or into the header tube. It allows you more leniency on the exhaust setup. (Can be a little more restrictive, allow you to run cats/quieter exhaust etc)
3) If you are turbo the lower duration (intake side) cams can actually help spooling in most cases.
4) Much easier to tune and better drivability both idle and part throttle/cruise
Originally Posted by 2002/Black/SS
i have the lingenfelter gt-7 cam with 208/230 on a 121LSA (crazy LSA) i havent dynoed yet but i think im the only one running it on here, and it actually makes some good power n/a!
I got that cam also installing in sts kit, numbers soon in a billion years.
