procharged 6.0
procharged 6.0
how much boost will a stock 6.0 shortblock handle and what kind of power should i expect to make on a stock engine with a f1/ carb set up? do i just need a 98 - 02 k member to install this engine in a 6 cyl 93 camaro chassis? also how big of a slick can you fit under a non mini tubbed 4th gen with out it sitting all jacked up and the tire sticking out
Typically stock pistons and rods can survive with 500-600 rwhp with a very safe tune.
If you want powersteering, youre going to need a rack and pump from a 4th gen v8 car. What size tire underneath the car would depend on width and heigth combined. You can fit a 28x 10.5,28x10.5w, 29x10.5, i've even heard of some running 30'' tires on non-mini tubbed cars.
I recommend shooting for 8 psi with a stock bottom end. I also don't like to see the rwhp on my Mustang Chassis Dyno go much past 500 with a stock bottom end. This would be about 550 rwhp on a DynoJet. Some survive past that mark, but most don't. Bob
