Should I Put My Stock Crank Pulley On With Fi?
the ati will control vibration better and when pinned it is much stronger (less chance for slipping on the crank. and they look good:-) also like stated above go with stock size...they will cool better and with fi you wont see any appreciable difference in power. i have anew one with ac pulley and pinning kit if intersted.cheap..
Yea I am not going for crazy power and I am not going to be winding my motor u[ to any major rpms, I'M only going to plan on running about a safe 7psi hoping for about 430 horses at the wheels. I just need some extra cash for some items for my turbo project and thought that I woulde no longer need the under drive.
Your fine with the stock balancer, just keep an eye on it, especially if you have a front mounted turbo thats close to it. The heat will destroy the rubber layer.
