D1SC and F1 Boost levels with a 346
Old 01-15-2007, 12:59 AM
kp
kp's Avatar
Default D1SC and F1 Boost levels with a 346
Went through a few logs and put this together, figured it may be of some interest. Similar DA for all of these. Some of the RPM values arent exactly lined up but you can get a good idea whats going on with them.
The F1A is 6K under max impeller speed, I'm scared to try to max it out just yet. IATs are similar to the D1SC maxed out.
Old 01-15-2007, 10:17 AM
kp
kp's Avatar
Here is a quick graph also, the sharp rise/dip around 5500 is where the converter locks so thats why the curve gets a little screwy there. But its easy to get the general idea..
Old 01-15-2007, 06:38 PM
White.Lightning's Avatar
Good data KP. How do you like the new blower so far? Is it a night and day difference? What is the smallest pulley you intend to use with the F1?
Andy
Old 01-15-2007, 06:50 PM
kp
kp's Avatar
The 3.7 will max out the F1 @ 7000rpm.
Its running decent with it, only was able to make a couple passes. Doesnt really feel that much different but its pretty loud
Old 01-15-2007, 06:56 PM
SSmokin 01's Avatar
Thanks for the info .
Old 01-15-2007, 08:08 PM
BLASTER's Avatar
Thanks for the data!
This gives folks like me a good idication of where I would need to stay if I was going to go with the F1A.
Old 01-15-2007, 09:09 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Great data KP.
Old 01-16-2007, 06:05 PM
stevieturbo's Avatar
Pulleys aside...Im surprised it takes to circa 5500rpm, for the boost difference to really show.
I'd have thought the bigger blower would have picked up boost much earlier too....
Or are the graphs not WOT throughout ?
Old 01-16-2007, 06:38 PM
kp
kp's Avatar
They are WOT off the trans brake, it accelerates so quick before the converter hits its really not that accurate down low since the boost is rising very quick.
But on the brake at WOT @ 3500rpm there is little difference between the F1 where its pulleyed now and the maxed out D1. I woult guess the bigger blower is going to give up some low end at the expense of flowing more up top. There is a big difference in impeller design between the F1A and D1SC and I'm sure its optimized to move the most air close to max impeller speed.
These are just numbers from my dragstrip logs, a manual transmission car and a dyno pull in high gear from 2000rpm-up would probably be more accurate since these numbers are taken in 1st gear (car never sees under 6200rpm the whole way except first gear) in 1.25 seconds there is probably some error.
Old 01-16-2007, 06:54 PM
Got Me SOM's Avatar
so you have about 2-3 more lbs after 5,000 rpm. I say pulley it down and max it out ya know you want to!
Doooo eet!
Old 01-16-2007, 08:25 PM
kp
kp's Avatar
Doooo eet!
I'll do it with a bigger engine, 20psi is enough for the little 347 right now..
Old 01-17-2007, 05:17 AM
Gold Phoenix's Avatar
what are you engine specs? what intake are you using? also, any guesses on an F1R on a large cammed 402?
Old 01-17-2007, 09:23 AM
Got Me SOM's Avatar
ya thinking bout doing that next season or sometime this year.
Old 01-17-2007, 10:11 AM
kp
kp's Avatar
All the engine specs are in the link in my sig.
I cant even guess on the 402/F1R.
Old 01-17-2007, 10:12 AM
kp
kp's Avatar
Probably next year if the this short block holds up, I'm in no hurry.
Old 01-17-2007, 11:37 AM
Nasty N8's Avatar
Cool can not wait to get our 402 and F1A up and running.
Nate
Old 01-17-2007, 12:02 PM
Got Me SOM's Avatar
KP if i ever decide to built a badazz sat night special car/wknd warrior fun car I'm copying your exact setup.
I'm sure you got high 8's easy.
Old 01-17-2007, 03:13 PM
kp
kp's Avatar
Well you know the main reason I started this whole thing was because I just wanted to show people that anyone with a garage and a few hand tools and a little mechanical ability can easily buid a low 10 second, high nine second car.
There is nothing on this car that anyone cant just go out and buy and bolt on, except for the roll cage of course but that doesnt make the car go any faster.
I was planning on going turbo long ago but honestly this setup continues to surprise me and I havent found the limit yet, sometimes you just dont fix what isnt broke
Old 01-17-2007, 03:18 PM
That about sums it up!
Andy
Old 01-17-2007, 03:20 PM
KP-
Activate your signature so people can get your links.....
Andy
Quick Reply: D1SC and F1 Boost levels with a 346
