Coolant fill tank relocation?????????
Old 01-25-2007, 08:50 AM
1INSANEGTO's Avatar
Default Coolant fill tank relocation?????????
This has to be relocated with a OFI kit and on 2005 its built in the the rad
Now where do I mount this thing? Everything I have read that there suppose to be mounted above the engine well a tube comes out of the bottom and goes to the bottom so can it be mount lower on the GTO's?????????????????
To give you a idea see the pic of what I am working with. Mine is like this but a lil round.
Old 01-25-2007, 03:27 PM
1INSANEGTO's Avatar
Hello???????????????????????????????????????
Old 01-25-2007, 03:42 PM
fitz98ta's Avatar
i do know you can't mount it low, mine is and isn't working right.
from that pic it looks like you run a hose from the bottom port to the valve so you can drain it easily. you will have to run the hose from your radiator to the top port in the overflow keeping it as high as you can. I will be putting mine in front of the radiator some where.
Old 01-25-2007, 04:21 PM
1INSANEGTO's Avatar
I don't know how true this is but I was told as long as the cap is over the head and the rad then it would be fine with that said I would have to exstend my tank neck
Old 01-25-2007, 04:29 PM
1INSANEGTO's Avatar
You know I have a setup out of a 1997 Mustang GT. and I think it will work....... I shall find out when I get home and I will post pics and I think you could use the same setup.
Old 01-25-2007, 07:30 PM
1INSANEGTO's Avatar
guess what it fits!!!!!!!!!!!!!!!!!!!!
Old 01-25-2007, 08:01 PM
Blown Ta's Avatar
since i am using my stock overflow for alky, i bought a
recirculating overflow from jaz and mounted it on the pass, side
fender, where the a/c drier used to be. works perfect.
Old 01-26-2007, 04:08 AM
8100hammer's Avatar
Could you switch out to a 2005 GTO radiator??? I think tish bigger too.
Old 01-26-2007, 06:56 AM
1INSANEGTO's Avatar
Yeah $275.00 later and thats for a used one........
There is alot of stuff that was done different on the 05's Seeing how the kit was built off a 05 and I have a 04 I am hitting all kinds of issues
Old 01-26-2007, 10:46 AM
MIGHTYMOUSE's Avatar
i have used a cheap o pep boys white plastic overflow in front of my passenger front tire for 2 years without problems.. always worked fine....exept when i had blown head gaskets...not the overflow's fault.
the stock ones on f body's connections are below the top of the radiator and below the engine... mine is only a few inches lower than that.
Old 01-26-2007, 10:59 AM
TurboGoat's Avatar
i just got a used 05 from a wrecked GTO, the radiator was fine.
Quick Reply: Coolant fill tank relocation?????????
