F1C/F1R on 6 Litre Iron Block?
Old 02-05-2007, 11:07 AM
HUNTER02SS's Avatar
Default F1C/F1R on 6 Litre Iron Block?
Has anybody had any problem's with this since you have to drill out the one hole in the block.Do's it hold o.k??I am going to be running alot of boost and want to make sure of the tension that will be placed there.?Thank's
Old 02-05-2007, 11:54 AM
koji777's Avatar
no prob at all.... did mine on the car.
Old 02-05-2007, 12:28 PM
HAMRHEAD's Avatar
It will hold fine
Old 02-05-2007, 01:05 PM
cablebandit's Avatar
sounds fast!!!!
Old 02-05-2007, 01:28 PM
Dumb Ass Vette Moderator
ls1290's Avatar
I am running a C5 F1-R kit on my 6.0L block without any mods.
Keith
Old 02-05-2007, 02:55 PM
BIG BAD BLACKSS's Avatar
Did you guys try to tap for that last bolt? Or leave the one out?
Old 02-05-2007, 03:54 PM
7 Second Club
ty_ty13's Avatar
i havent had a chance to drive mine much yet but i have not tapped the extra hole....
i'll see if theres flex or belt dust...
Old 02-05-2007, 04:57 PM
HUNTER02SS's Avatar
i just got done looking at again and I have already tapped the hole on the block.It's the one on the top,and then I have one on the bottom but I have no middle bolt hole. It is just the casting of the cylinder bore.So i only have 2 mount locations,1 on top that I tapped out and the 1 on the bottom.No middle one. Is this the way all iron block's are.???
Old 02-05-2007, 06:34 PM
Ive heard talk of some people tapping the third bolt, i guess you have to be very careful but you can do it? Its very sketchy anytime its brought up, havnt heard any good safe way to do it yet, if its really eaven possible!
Old 02-05-2007, 08:44 PM
7 Second Club
ty_ty13's Avatar
i dont particularly like it but if it comes down to it i may try...
Old 02-05-2007, 09:05 PM
HUNTER02SS's Avatar
i know I am not tapping the one where the cylinder bore is.My luck I will end up with a damn bolt in the water jacket!!! I am considering swapping to a corvette accesorie set up and putting the blower on the passenger side.Do's not seem to bad to do??
Old 02-05-2007, 10:04 PM
7 Second Club
ty_ty13's Avatar
i've looked at the GTO bracket... it makes more sense to me....
Old 02-05-2007, 10:27 PM
Bird-Of-Prey's Avatar
Does anyone know the depth of a D1SC headunit from the pulley to where the inlet hat would be? I have 10 1/2" - 11" between the outer rib of my serp belt and my radiator. Although I don't have the bracket and headunit yet, by looking at every pic I could find it looks like it will fit without an issue if your radiator support is cut for a custom radiator.
Old 02-05-2007, 10:43 PM
Here's a pic of how much room I've got:
Old 02-06-2007, 12:55 PM
TNTramair's Avatar
im wondering the same thing for a F1r...if i keep the stock radiator, whats all involved in making it fit??
Quick Reply: F1C/F1R on 6 Litre Iron Block?
