HP potential calculator......turbo engine
twin 88mm turbonetics on a 454ci LSX iron block 9.7 deck. 410cfm heads. 1700cfm TB. Hogan intake. 9:0 cr I believe.
Can ya figure it out? What other info do ya need?
Originally Posted by 2001-WS6
I did the calculations and it came back........
"Unfricking Hookable for any Florida Highway Roll Racing"
Sorry... I couldn't resist.
Rick
Rick
Originally Posted by black98ws6ta
What do you want to know? It could make 2000 rwhp if the motor can take it, and that block is supposed to be able to.
Edit... I am a dumb ***. Twin 88's... Dee de dee
Great, another bench racing thread by the master himself.
What happened to the 44XCI motor you were building? Or the BBC TT C6? Or the 1500rwhp turbo 436CI? Or the 650rwhp NA motor?
I'm going to guess the same thing that will happen with this setup. It won't.
Originally Posted by Ping King
Engine Capacity?
Naturally Aspirated CFM?
Air Temp beofre intercooler?
Air Temp Drop?
Air Temp after intercooler?
Whats the purpose of the set-up?
I guess it's easy for you to confuse someone asking for a power calculator, for "hey guys look what I'm having built next week."
When you plan to spend a shitload of cash on a set-up, do you just buy something quickly or do you research every possible option? What a sap. Have a nice day jealous boy.
you fill in the left...it fills in the right
This is what I put on the left.
4.125
4.250
8
6500
85
75
35
70
no water temp (it won't take it no matter what I do)
75
"no water temp (it won't take it no matter what I do)"
Click on "air to water" than it will take the water temp of the a-2-w system.
Mine came to 1460 hp - supposedly to the flywheel -- 1460 x .80 = 1180RWHP - fairly close to what we figured on my engine at 20lbs of boost.
David
David
David
David
What water temp to use? It won't be an A-2-W cooler though, just A-2-A. Is there a big difference between the two in power?
