juist got my wideband in, where do I put the bung?
Old 02-15-2007, 03:51 PM
lmt0705's Avatar
Default juist got my wideband in, where do I put the bung?
can someone tell me the best place for accuracy to weld in this o2 bung, which side and how far back?
Old 02-15-2007, 03:55 PM
pdanrichey's Avatar
I'd just take out one of the rear o2 sensors and put it in there. Then, just kill the code for the rear-O2...easy as pie!
Old 02-15-2007, 04:35 PM
98turbls1's Avatar
Don't do that if you have Cats... The temps behind there will burn them up...
Old 02-15-2007, 04:39 PM
98turbls1's Avatar
What kind of WB do you have?? On mine I put it in the right front and wired the narrowband option to the factory signal wire... It reads it just fine but you have to have the ground wire in the factory harness grounded...
Old 02-15-2007, 06:21 PM
Blown Ta's Avatar
i put mine on the y pipe, before the cats, close to the stock front 02
sensors.
Old 02-15-2007, 06:30 PM
Boostaholic's Avatar
I had mine about 4 inches after the turbo on my passanger downpipe. worked great
Old 02-15-2007, 06:37 PM
Josh@KY-Turbo's Avatar
That where I would recommend putting the WB. I usualy run them with in 18 inches of the turbo in the down pipe.
Old 02-16-2007, 08:10 AM
smokinHawk's Avatar
well since he has a supercharger id put it in the Y pipe, if you dont have cats, or just after one of the collectors if you do
Old 02-16-2007, 11:41 PM
lmt0705's Avatar
sorry I should have mentioned I running true duals with no cats
Old 02-17-2007, 10:23 AM
pdanrichey's Avatar
If you have any part of the stock y-pipe left, use the bung for rear O2's on the passenger side. I figured you weren't running cats.
Quick Reply: juist got my wideband in, where do I put the bung?
