OFI 4" downpipe with stock accessories!!!
Old 02-17-2007, 02:30 PM
LS1TECH Sponsor
tt427ls1's Avatar
Default OFI 4" downpipe with stock accessories!!!
Well I finally got around to finishing up the mockup of the 4" downpipe. The downpipe is all stainless steel with a cone reducer from 5" to 4". Comes with the flange and v-band clamp to attach to the turbo. Will use a 4" band clamp to connect to the test of the exhaust. I had to order one sense no part stores around me had them in stock.
Some mods that need to be done to make it fit are...The alt looses the back mounting bracket and you must cut the tab off the back of the alt to make it fit better. I didnt cut the alt that I have here in the shop b/c this one is not getting this setup. If you cut it you will gain more room and it will not touch anything. From the pics the steering rack is off in the pics. When you cut that tab you can fit the sterring shaft on the rack with room to spare.
The swaybar will fit with the 3/8 spacers that I provide with the kit. The swaybar bracket on the driverside will have to be modifed also. Will have details on that when you order the setup.
You will have to make custom power steering lines unless you want to just bend your factory ones to make them fit. Its up to you for that. Agian I didnt do that sense this car is not getting this setup.
This Downpipe will be made in house by hand from the turbo to the " I " pipe.
Upgrade price for this setup is going to be $495 for the first section. Which stops right in front of the trans. You can have it connect to a 3.5" or 4" pipe to the " I " pipe the rest of the way. I would recommend the 3.5" for lowered cars...cause this 4" is big! This is also done with the UMI K-memeber. I have no ides right now if the stock would fit. The UMI one is a real nice setup. Gives you romm to work.
Old 02-17-2007, 02:52 PM
Snyper's Avatar
damn...looks close.
Old 02-17-2007, 04:19 PM
TINKRD's Avatar
looking great buddy. With your cross over pipes and location of the turbo, can you retain the factory radiator or do you need a custom radiator? also w/ the location of the turbo, can the oil line be gravity fed back to the oil pan or do you have to buy a scavenging pump?
shoot me some prices w/ the cross over pipes for the t6, support bracket and 4in DP b/c i'm really interested. :beer:
Old 02-17-2007, 04:27 PM
black98ws6ta's Avatar
That looks like it will have clerance problems where the downpipe goes under the floorpan of the car.
Old 02-17-2007, 04:30 PM
LS1TECH Sponsor
tt427ls1's Avatar
The only clearence proplems your going to have is if your car is lowered. You can go with a 3.5" from that point back if you want.
Old 02-17-2007, 04:43 PM
Dbluegoat's Avatar
damn too bad we couldnt get a 3.5 or 4" DP
Old 02-17-2007, 05:53 PM
Got Me SOM's Avatar
sweet!
any numbers yet for your kit? hp numbers i mean
Old 02-17-2007, 07:55 PM
cablebandit's Avatar
you dick!! I knew it!! Alright how much? I will buy that one
Old 02-17-2007, 07:58 PM
UMI Performance's Avatar
Looks excellent Joel, Glad to the K-Member worked out
Old 02-17-2007, 10:35 PM
LS1TECH Sponsor
tt427ls1's Avatar
Thanks Ryan...your k-members are really nice. The really free up some room to work on the engine alot.
Will have some numbers for all you guys in the next couple weeks with this setup and a 4" DP.
Old 02-17-2007, 10:38 PM
LS1TECH Sponsor
tt427ls1's Avatar
You can use the factory rad, but you will have to stand it up. I dont know if you will have room for the a/c condensor though. The oil return is gravity fed back to the oil pan.
Will shoot you a pm.
TINKRD's Avatar
ttt..
Old 02-18-2007, 11:12 AM
Shoulder Shaker's Avatar
I was able to see this new down pipe in person and I must say it looks damn good. Thanks for everythnig Joel. Well be talkikng to you real soon.
Old 02-18-2007, 08:15 PM
smokinHawk's Avatar
looks good.
now there will be more people with a four inch downpipe, and to think i started it all (/sarcastic)
id like to see it finished hopefully it wont strape with it crossing over the driveshaft, think you could run oval pipe on the driver side to the back?
Old 02-18-2007, 08:29 PM
Smokinhawk, if i get one, i will run a cutout right off the 4" on the drivers side and the small junk to crossover and to the catback. I think ill get your bracket and move the alternator as well
Old 02-19-2007, 06:14 AM
02SSLE's Avatar
I have a 4 inch DP on mine but it really comprimises ground clearance.
Old 02-19-2007, 07:36 AM
smokinHawk's Avatar
ya that would work well with the cutout.
and moving the alternator up top might help you out clearance wise and prevent it from getting any heat, plus its easier to work on with it up there.
Old 02-19-2007, 08:24 AM
TINKRD's Avatar
any pics??
Old 02-19-2007, 01:16 PM
obZidian's Avatar
hey joel, you mentioned that we will need to modify the power steering lines. Will the bends be enough to cause failure in the lines or can they be bent and not worry about having a leak.
I ask because i have never done anything like that, modifying hard lines, and wanted to know if i should just go ahead and get a new set of lines or just deal with what i have already. Is there a specific tool, like a small mandrel bending tool, to do the job right?
Old 02-19-2007, 02:25 PM
93formto98T/A's Avatar
Nice work Joel, if all goes well I'll be having you do a new custom setup for me.
