Its no problem to run GM 6 liter gaskets with stock LS6 heads on LS6 motor right?
I heard some guys on a stock cubed LS1/6 motor will put on 6 liter GM OEM gaskets to knock down the compression a tad.
How much will this knock down compression on at stock 10:5 comp. LS6 motor and are there any problems that can surface by doing this?
Originally Posted by kp
If the gaskets are .50 thick for example you are looking at maybe .05:1 difference between a 3.9 and 4" gasket bore. Hardly significant..
i THINK the 6.0L MLS gaskets are ~.08 or so thicker than stock graphite - but i couldn't justify going from 5.7L MLS gaskets to 6.0's
Bro-this is eb02z06 from the CF forum- 6.0 and 5.7 gaskets are the same thickness-you would need to get a set of gaskets from cometic in a .065 thickness for a drop in CR but then again it would go from say 10.6 to say 10.2.
It will change a little between the 5.7 and 6.0 gasket even if they are the same thickness.
Easier to do 72cc heads IMO if you want to drop the compression..
Originally Posted by Vortech
Kp is right-the bore diameter also plays an important role-Bro-did i tell you your crazy?
None crazier than you BRO!!
