Launching a turbo car
Old 03-07-2007, 12:01 PM
1INSANEGTO's Avatar
Default Launching a turbo car
Well my car will be done tommrow and I wanted to get some tips for when I do some tests friday.
I have a 2step and its set to 3500rpms T76 Turbo
Is there anything I want to look out for any tips? this is my first turbo car every. With a exp driver it should be a low 10 high 9 car in the 1/4.
Fastest I have ever been down a track was 13's in my mustang
Let me know any tips and I am willing to listen.
Old 03-07-2007, 01:48 PM
1INSANEGTO's Avatar
13 views and no feedback what gives?
Old 03-07-2007, 01:51 PM
Wnts2Go10O's Avatar
i would up the 2 step. 3500 seems a lil low to me. depending on tires, make sure they spin a little bit so you dont bog.
Old 03-07-2007, 01:53 PM
JD_Z28's Avatar
The only advice I could give you is make sure to warm the tires up good and just fiddle with the 2 step. If you don't hook at 3500 drop it and if it hooks good try to raise it a little and do a comparision. Good Luck.
BTW what A/R are you running on the compressor side?
Old 03-07-2007, 02:47 PM
SSilverSSurfer's Avatar
arent you still on the stock IRS?
Old 03-07-2007, 03:24 PM
1INSANEGTO's Avatar
Yup but with full Pedders drag springs. Main isssues with the GTO's are wheel hop that pretty much takes it out.
Old 03-07-2007, 04:10 PM
99Z28LS1's Avatar
im curious to know more about launching a manula turbo car with a 2step, gotta be amazing
Old 03-07-2007, 04:46 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Here is how I launched mine when I first made passes... it was the wrong way.
I had my 2step at 3500. I have the 2step wired to the trans break, so I would stage and then engage the 2step, and bring up the motor. In my car I can have it floored and it takes like 2 seconds or more for it to come up and start stuttering. I was letting go the brake and launching. Afterward I found out from the gurus on here that I did not build boost, and needed to watch the boost gauge. So the lesson for me was just because the revs were up did not mean I was boostin. So when I launched the car nosed over and then took off about seven cars out... resulted in me running 9.8@141.
So make sure you are seeing boost. When I practiced later I was seeing 10psi on the street. And when I released the brake the car launched hard and I let out a big YAHOO.
Old 03-07-2007, 07:38 PM
Coal Mining Director
onfire's Avatar
Do you have a transbrake and a 2step? Big difference if you only are using a 2step.
If you're used to 13's I would start the 2step down low until you get used to the car launching....crap happens real quick in a 9 second car.
If you're using the 2step and a tb, set the 2step to 2500rpm and make a run....then start upping the 2step to meet you goals.
If you're using a 2step by itself, start at 2000 rpm and move up 100rpm at a time until it pushes you through the footbrake.
Good luck!
Old 03-07-2007, 08:25 PM
1INSANEGTO's Avatar
This is a M6 car
Old 03-07-2007, 08:52 PM
quicksilverado's Avatar
As stated above you may want to up the boost in steps. Going from 13 sec to 10s will get scary real fast and its hard to react when your not used to the power increase. I went from a 14 sec to low 11 sec truck in steps just for that reason. Good luck.
Quick Reply: Launching a turbo car
