adjust mondo bypass valve?
Old 03-16-2007, 07:15 PM
Blackbird's Avatar
Default adjust mondo bypass valve?
i notice you can loosen the nut and screw the screw in or out on this guy.
what effect does it have screwing the screw in vs out?
Old 03-16-2007, 07:21 PM
frcefed98's Avatar
I just left it set to factory adjustment, worked flawlessly.
The instructions say that the factory setting should be good for nearly anything that isn't an all out race application.
I know this doesn't remotely answer what you asked, but hey i'm just putting it out there....better than posting up in the PCM section and not getting and answer
J
Old 03-16-2007, 11:04 PM
Blackbird's Avatar
so info is better than none
I guess I will just try it both ways. this one flutters instead of whoosh when you get off the throttle, I could be wrong but it just doesn't seem like it's opening all the way.
Old 03-16-2007, 11:13 PM
frcefed98's Avatar
hmmm mine went PPPPPPPPPSSSSSSSSSSSSSHHHHHHHHHH!!!!!!!!!!!!! when I had it on the procharger set up...thats when I let off the gas after boosting.
J
Old 03-16-2007, 11:16 PM
Blackbird's Avatar
as did mine.
this one is on my buddy Jason's TA.
thus my inquiry on adjustment, this one just doesn't seem to behave the same.
Old 03-16-2007, 11:17 PM
Ping King's Avatar
are you using it on a blower or a turbo?
Old 03-16-2007, 11:22 PM
frcefed98's Avatar
works equally well on either set up as vortech rec's em for either turbocharged or supercharged set ups.
Old 03-16-2007, 11:34 PM
Ping King's Avatar
i actually used one on my turbo setup, im just wondering if theres any difference between operation because theres different characteristics between the two.
Old 03-16-2007, 11:58 PM
Blackbird's Avatar
this happens to be a blower setup.
Old 03-17-2007, 09:14 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
J
Plus 1.
Old 03-17-2007, 07:17 PM
DeltaT's Avatar
I have never heard a peep from mine, but I do have it dumping right out of its port into the Vortech inlet. Maybe the new T-trim will give it some exercise!
I tightened my adjustment screw four turns in to make it close a little faster, but it didn't make a big difference.
Jim
Quick Reply: adjust mondo bypass valve?
