My good luck has ran out...
Old 03-24-2007, 04:39 PM
Tiago's Avatar
Default My good luck has ran out...
Last weekend during the Supra nationals I was beating on the car HARD... and boost maybe running a little higher then usual lol and I noticed the car sliding a little bit on a top end pull, then it proceeded to run a little hotter babied it home to find coolant sprayed all over under the hood. Overflow tank looked like a M-80 went off inside of it
I let it sit all week and confirmed today. I did a little experimenting to make sure it wasn't knock causing it, sure enough no knock was seen and it still lifts the heads. Time to tear it down. I guess I can't complain about a solid year of beatings it took at that level. The damn 346 from hell is still kickin though... gotta make up my mind if I pull it out now for a refresh or just swap gaskets......
Was fun though
Old 03-24-2007, 04:50 PM
raymond mckinney's Avatar
What's this car put down over 1000 wheel right? Aleast where u winning?
Old 03-24-2007, 04:53 PM
Mike 01WS6's Avatar
Yeah no ****....if you were winning....thats all that matters.
Old 03-24-2007, 04:55 PM
kp
kp's Avatar
I never had any problems like that with 18-20psi on pump gas.
Sorry, had to
Old 03-24-2007, 04:58 PM
Tiago's Avatar
Sorry, had to
LOL you know better then that
I was runnign VP109 and 18-20 psi at ~1000 rwhp. It has always been a matter of time
Old 03-24-2007, 05:00 PM
ninetres's Avatar
What kind of times were you pullin?
Old 03-24-2007, 05:01 PM
lbz34's Avatar
C-16 Ftw
Old 03-24-2007, 05:04 PM
Tiago's Avatar
Originally Posted by lbz34
C-16 Ftw
what for? it had no knock at ~18 deg of timing .
O2s would die
WG's would die
need to revise soem **** to convert over, and there is no point unless I want to turn it up higher which I will now.
Old 03-24-2007, 05:15 PM
kp
kp's Avatar
Actually my sensors are two years old and C-16 or sunoco supreme (112 R+M/2)hasnt kiiled them yet. That shitty track-tech and turbo blue stuff will kill them in an hour though, its like 1/2 lead I think
Old 03-24-2007, 05:26 PM
frcefed98's Avatar
Man sucks to hear that Tiago, but glad she held together for so long at those levels.
Hopefully you can find a way...all you high boost/hp guys find a way to keep the heads on these
Old 03-24-2007, 05:34 PM
Tiago's Avatar
I run VP fuels... I have ran a ratio of 3 to 2 gal of 109 and c16 and it owned my sensors in about 20 gallons of gas.
Old 03-24-2007, 05:52 PM
Got Me SOM's Avatar
What times did you run?
Old 03-24-2007, 06:02 PM
lbz34's Avatar
O2s would die
WG's would die
No knock but the heads lifted. C-16 FTW.
Old 03-24-2007, 06:05 PM
kp
kp's Avatar
Its probably the MMT in the 109 doing the owning not the C16, like I said, same pair of wideband O2s for 2.2 years in my LC1s and the BS3 has seen nothing but C16 or 112 leaded sunoco since its been in the car and all the sensors still work fine. Unless you are talking about the narowband sensors, they dont work long at all with leaded. I used to use the 104 unleaded sunoco mostly but that stuff would leave everything brown from the additives and kill the stock sensors pretty quick as well - thats one of the reasons I switched to the BS3 to get rid of the narrowbands O2s.
Old 03-24-2007, 07:50 PM
99Z28LS1's Avatar
that sucks man. i will always wish to be as lucky as you were when you made that much power out of your 346
Old 03-24-2007, 09:50 PM
Tiago's Avatar
explain the science of how the the C16 would have kept my heads down
KP, yes Im talking about the narrow bands. I wont be going BS3, Im going to switch over now to a FJO dual chanel WB system to feed the stock pcm, no need for BS3
Old 03-24-2007, 11:10 PM
SSilverSSurfer's Avatar
dammit man, you cant complain she was solid for a while, i was just talking about how your car has been flawless and this has to happen, lol,
oh well more time for my car, lol, just kidding
Old 03-24-2007, 11:19 PM
lbz34's Avatar
Not trying to start a fight nor argue.
Do what you like.
Everyone is different
Old 03-24-2007, 11:24 PM
frcefed98's Avatar
OK OK stop with the that damn lil smilie is the biggest fight starter know to man
back on track...
Old 03-25-2007, 12:13 AM
lbz34's Avatar
lol Just copying.
Tiago knows I love him.
Quick Reply: My good luck has ran out...
