Another DIY turbo build
Old 03-28-2007, 10:47 PM
code4's Avatar
Default Another DIY turbo build
DONE!
My wife & I have been working on this almost daily for 6 mos. It is not in the same leage as a lot of the cars on here but we love it. It is absolutely bad *** on the street. This is my first gen III engine build & first turbo build.
I want to thank ls1tech & all the sponsors that make this site possible.
Details:
LS6 Block
forged -4 cc pistons
forged rods
stock crank
AFR 225 heads
TR224-114 cam
TC 76 turbo
Nasty Stage II with my own dual pump fuel system
Full "mostly" BMR suspension
Turbo 400
Vig 3k stall
9" rear
hell I can't remeber what else, here's some pics
Old 03-28-2007, 10:55 PM
code4's Avatar
and mo pics:
Old 03-28-2007, 10:56 PM
topgun77's Avatar
lets see some pics, no one can say you havent been working hard on it.
Old 03-28-2007, 10:59 PM
Coy
Coy's Avatar
Nice!!
Old 03-28-2007, 11:07 PM
Josh@KY-Turbo's Avatar
Nice work.
Old 03-28-2007, 11:10 PM
datsbad's Avatar
who's alternator set up did you use? what belt length .
Looks sweet !!!!!!!!!!
Old 03-28-2007, 11:12 PM
code4's Avatar
It's the stainless works cheapy with stock length belt. It was a PITA to get lined up correctly.
Old 03-28-2007, 11:24 PM
98turbls1's Avatar
Looks really good bro... nice to see it going... When you putting it on the rollers??
Old 03-28-2007, 11:50 PM
96silverram's Avatar
Congratz on all the hard work !
Old 03-29-2007, 12:28 AM
THE_SUPRA's Avatar
NICE! you guys will love the power! good luck on the car.
Old 03-29-2007, 07:54 AM
smokinHawk's Avatar
looks good, well done.
Old 03-29-2007, 08:25 AM
half-n-half's Avatar
looks good man, i have the same exact thing going together in the next month or two myself...
Old 03-29-2007, 09:04 AM
70Stang's Avatar
Well done!
Old 03-29-2007, 09:33 AM
98'SS's Avatar
What kind of power you hoping to put down? Looks great!
Old 03-29-2007, 09:45 AM
RealQuick's Avatar
Nice!
Old 03-29-2007, 11:01 AM
code4's Avatar
No dyno close to us. I have taken it to ~9 lbs of boost & started getting 1 to 3 degrees of KR. I have around 150 miles on it. I'm trying to decide on what racing gas to order.
The elec cooling fan is taking a beating from heat off of the turbo. I ordered a turbo blanket from Jose.
Old 03-29-2007, 11:09 AM
NA$TY-TA's Avatar
Looks good..... what fuel are you running in it now and what tuning have you done so far?? How much timing?? What are you using for tuning??? 3 BAR setup??? Wideband???
Old 03-29-2007, 11:39 AM
98turbls1's Avatar
Maybe you should try a progressive methanol injection kit...That would help with KR on the street atleast and then put some racing fuel for the track... Awesome work again bro... When I bought the KB BAP off of you your wife told me about it...She wasn't lying when she said that it's going to be nice... =)
Old 03-29-2007, 11:45 AM
code4's Avatar
92 octane pump gas. I have the 2bar hpt set up with a lm1. I have my AFR's looking pretty good except decel which I can't fix. I am running 12 degrees across the board while in boost. My iat's are a chillly 60 to 65 degrees. I thought it could handle 9 lbs. My CR is ~9.1 to 1 if I figured it correctly.
Old 03-29-2007, 11:48 AM
code4's Avatar
Thanks for the kind words.
Yeah I thought about meth but I would rather not have more stuff to worry about not working etc. I'll research it some more.
I put a drain in my tank so I can switch over to race gas when needed.
Quick Reply: Another DIY turbo build
