Heads on procharger???
I saw the other procharger head threat but i had a little different selection on heads. Plan on ati procharger next year and i want to do heads first. I was looking at afr 225cc or lq9 patroit heads. Which is better for my set up. Also what do you think i will get out of the power gains.
Thank you guys.
Thank you guys.
It really depends what the budget is? The afrs are pricy, but proven time and time again, the patriot is a all around awsome budget head that works great with FI and NA, for the $$ it is very worth it.
Are you planning on staying stock bottom end? If not then i would get heads, if you want only around 500hp then the stock heads are fine with 8psi with a ATI.
Originally Posted by BorlaTA
Difference between the afr 205cc and the 225??? Plus im on a stock bottom end.
A very good and inexpensive head to use is the Patriot LQ9 Stage 2 heads, which will drop your compression ratio slightly. We use these heads up through 16 psi, past that amount of psi, I would go with a thicker head deck, such as what the AFR heads come with. Bob
I went with West Coast Racing Cylinder Heads (WCCH) stage 2 LS1 blower heads.
Lowered the compression a little with the 71cc chambers (9.4:1 with my -4cc pistons), and they are CNC ported with their Stage 2 port job. Richard is very helpful in discussing your goals and picking out what you need, and it won't break the bank.
I'm making 740+ torque on 8.5psi and a 50 shot with an LS6 cam and shorty headers - on STOCK cubes. (Well, 1 more ci than stock, W2W forged 347).
Rob (Bad30th)
Rob (Bad30th)
