How much boost would you run on SCAT rods (w/ARP bolts)???
Old 04-22-2007, 06:53 PM
SideStep's Avatar
Question How much boost would you run on SCAT rods (w/ARP bolts)???
Subject says it all....
Doing 383/Super Charger build and i wanted to hit it with 5 - 7 pounds of boost (w/alky). Will the Scat rods handle it???
Any help appreciated...
Old 04-22-2007, 07:41 PM
camarols1's Avatar
Are the Scat rods H-beams?
If so, they will take much more abuse than 5 - 7 psi.
Old 04-22-2007, 07:42 PM
JMBLOWNWS6's Avatar
I would reconmend using the ARP 2000 bolts.
Old 04-22-2007, 09:31 PM
FastKat's Avatar
A little boost isn't going to kill rods, engine speed (high RPMs) is going to kill rods. Scat rods will be 110% up to the job, as long as you stick around the stock 6200-6500rpm redline.
Old 04-22-2007, 09:52 PM
motorbuilt's Avatar
Ive made 1150 to the tire on out of the box SCAT h-beams in a turbo mustang with the arp rod bolts that come in them
Old 04-22-2007, 09:59 PM
HUNTER02SS's Avatar
I have scat h-beam rod's also in my twin turbo car.No problem's!
Old 04-23-2007, 06:14 AM
SideStep's Avatar
Thanks for the info...
I plan on a small blower cam/Maggie-OR-KB (w/alky)/383 setup... no high revs planned...
Old 04-23-2007, 02:50 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm running H beam rods, have seen 26psi.
Old 04-23-2007, 02:54 PM
kp
kp's Avatar
Its easy to figure it out, keep turning it up a little until one bends or breaks. Then run 2psi less then that when you put it back together
Old 04-23-2007, 03:37 PM
SideStep's Avatar
WOOF!!!
Don't laugh, but I would like this to be my last round of mods for a while... and actually get to drive the car...
Old 04-23-2007, 04:03 PM
stevieturbo's Avatar
boost wont break rods, and boost wont break rod bolts....
rpm's will though. Keep them sensible, and Im sure you can make as much power as you want with them without worrying.
Old 05-16-2007, 10:21 PM
obrien24's Avatar
If I wanted to build a motor to spin up around 7000 to 7300 or so, will the scat or callies compstar rods work?
Old 05-16-2007, 10:30 PM
11Second Club
Gauge's Avatar
I'm turning 7k on my Compstar rods without any problems. I beat the **** out of my motor, too. They're a quality piece according to my research and my fairly brief (5k miles, 75 track passes) experience.
Old 05-17-2007, 09:15 PM
camarols1's Avatar
Either will work fine.
The bolt upgrade on the Scat rods is cheap insurance for big RPM's.
Quick Reply: How much boost would you run on SCAT rods (w/ARP bolts)???
