Top guys opinion on high compression, high boost, low timing.
I have bee talking to Phillip Bridges for awhile now (so of you may know him or know who he is).
Now he has a turbo LT1 Trans Am that he was running the lt1 forever and now to a dart little m.
His theory is opposite of what you most drive for when putting together a F/I setup. The title states it. What do you guys think?
Im not giving exact specs but .... running something like 10.2ish/1 with something around 16psi (on pump) and timing like 12* on a smallblock. Thats not very much timing for a SBC
He has ran something in the area of 8.82ish the other weekend ( i think) on his race gas tune... trapped i think a best of 176 or something mph...
Oh... and still on the same plugs as last year... looking good
so whats your guy's opinion...
LS1Tech Sponsor
There is many variables to account for. When it comes down to it, cylinder pressure is key. Where, when, and how much you have at any givin time (rpm). If he is running a cam that lowers dynamic compression a lot he can run more boost on pump with high static compression. This is just one of a million variables on a setup though. I have made some big power with boost on pump and high octane. On stock L31 vortecs I have made big power on boost while running 12-14 degrees of timing (under boost)on pump and having them live for a long time.
All I can say is its possible...
I have a Yamaha apex sled which I turbo'ed last winter and ran up to 18psi on ... stock pistons/rods...
Compression ratio is 11.8-1 and I am running stock timing on that thing.
Only thing is I have to run strait C16 to avoid knock.
287hp out of a 1 liter engine
I believe RPM plays a factor in this as well due to dynamic compression. High revving slow spooling small displacement engines like bikes can run turbos with 11.5:1 compression because they spool late and have less peak cyl pressure vs a large displacement fast spooling setup.
Someone correct me if I'm wrong.
In this case a 11K rpm redline engine... but even a 5-6K rpm... it had 17-18psi of boost on the dyno
Torque is about 180% of stock torque all the way from 5000 rpm to 10500rpm.
But peak cyl pressure increase by about 20% only (assuming no knock) but that should be the same thing with our LS1/LT1 engines.
Originally Posted by MIGHTYMOUSE
whats low about the timing? not much off from what i run with 8:1 compression
when my timing was totally wrong (like -10* at full boost) i was able to crank the boost up, but it never made **** for power compared to less boost more timing.
He is talking about a traditional SBC not an LSx based SB.
They usually run a good bit more timing then we do on the motor.
i've been thinking about this whole thing for a while, and everyone talk to thinks its a horrible idea, i think it would spool faster, the car would be more responsive. but i might be wrong
he said it does spool fast and runs good.
Usually boost makes more power than timing. And leaning out the afr. So running higher boost with reasonable afr and low timing can work. Lowering timing really seems to take away torque. Which can be a good thing maybe to save the drivetrain,rear end. It is debatable wether high boost and low timing or higher timing and lower boost are really that much different. The higher timing can make the car feel faster since as said the torque really can come up. I guess we need someone to come on with dyno graphs that has tried this. Mostly this is a pump gas or high compression issue. Run high enough octane and you should still get high boost and high timing and leaner afr.
fwiw my car felt a lot stronger at 10:1 compression than it does now at 9:1. If I decide to keep the car I'm gonna heads milled to bring the compression back up.
definitely had a lot more torque especially down low and the car felt snappier.
Gotta love Static compression.
Originally Posted by kp
Higher elevation can use much higher compression, even with pump gas.
