Turbo car overheating
Old 06-19-2007, 09:27 PM
02SSLE's Avatar
Default Turbo car overheating
Hey guys I am wondering what you turbo guys are doing to cool engine down? I am currently running setup in sig with stock radiator and a Flexlite blackmagic extreme which flows 3300cfm of air. When I set in traffic for a while it starts getting about 220 to 230 according to my factory guage. My turbo is in front of crank pulley with headers turned forward. I also have AC but not currently using it need to charge it. I have all the hot parts coated in Jethot 2000. I have drained antifreeze some of antifreeze out and put just water and some of Royal Purples ice. It helped some but still not enough. I have a 160 thermostat in it but I have a new one I just haven't put in it yet to see if that's it. After setting in traffic the engine bay just gets heat soaked I guess. Any help would be much appreciated. Thanks guys
Old 06-19-2007, 09:35 PM
Subliminal Hit's Avatar
the stock gauge is a dummy gauge. It has 3 settings...cold, normal, overheating. Only 98 f-bod's had a accurate gauge iirc. Run a aftermarket gauge.
Old 06-20-2007, 01:56 AM
SStolen's Avatar
blown headgasket?
Old 06-20-2007, 05:10 PM
02402RAMAIR's Avatar
brand new head gaskets on it. I had a blown one but have no issues now with that anyway.
Old 06-20-2007, 09:49 PM
BadgeZ28's Avatar
Several suggestions. A LT-1 radiator is about 1/3 bigger. They can be picked up pretty cheap and are a direct fit. You might need to seal off a extra outlet. Pushing air through the AC condenser is difficult because it is so dense. You might want to space it out to fit fans between it and the radiator, or add more fans. Good Luck
Old 06-21-2007, 10:02 AM
vipvegas's Avatar
Im having close to the same issue. I have an STS kit t67, I am in Nevada and its hot but never have I seem the temp on my car hit 230. The other day while driving on interstate temp would get up to 225-230 on the dummy gauge. The weirdest part of the whole thing is the vehicle cools down when I come to a stop or at a light. Doesnt do it all the time either. I have a 160 thermo, dont know whats going on plenty of coolant no leaks. Think Im getting blow by?
Old 06-21-2007, 10:32 AM
Zombie's Avatar
In the 100+ temps here in vegas my car runs 230ish with the a/c on (so does a stock car). I turn off the a/c if it goes over 235. With no a/c on in summer the temps don't go over 205. I know the LT1 radiator would help my cooling issues.
Old 06-21-2007, 10:37 AM
vipvegas's Avatar
Its getting hotter out too. Vegas weather suckssssssss.
Old 06-21-2007, 10:16 PM
02SSLE's Avatar
should I put fans on the condensor side also? (pushers)?
Old 06-21-2007, 10:42 PM
HUNTER02SS's Avatar
I would suggest yousing your stock fan's if you can.I have a griffin radiator and stock fan's.No problem's.The griffin rad is only 175.00 or so also. Cheap insurance!
Old 06-21-2007, 11:43 PM
EATON22's Avatar
You could make sure you have an oversized radiator; one thing that worked well for me was not to wait until the temp. got to 165 or 180 to turn the fans on especially in the summer. I have aswith that can turn the radiator fans on when I start the car. Keeps the water cooler longer. Also make sure your radiator can breathe air from the front of the car when you are driving. If you a have a turbo; a airconditioning cooler; and a tranny cooler obstructing your radiator from fresh air moving through it you will heat up in a hurry as well. LOL
Old 06-23-2007, 01:49 PM
vipvegas's Avatar
What would happen if you run no or open thermostat
Old 06-23-2007, 02:55 PM
RW99's Avatar
vipvegas, you're having a problem cooling at speed, which makes me wonder if you've done anything to the front air dam. The fact that the car cools normally with your existing thermo in traffic and when stopped means that your radiator/coolant/thermo are all capable of cooling when there's sufficient airflow. Your problem is the reverse of what most of us have, where the temps start to climb when the car is in slow traffic. But you've got an STS, which shouldn't be as difficult to keep cool when compared to front mount turbos. Do you use a FMIC or something else that might be disturbing your airflow at speed?
02ssle, trying to push air through the AC condenser to the radiator is tough to do. I ended up ditching my AC and putting pushers right on the rad. Others have managed to keep the AC, but I was just getting too hot in stop and go traffic.
Old 06-23-2007, 06:01 PM
Darren P's Avatar
how does your car handle stop and go driving
does it over heat
if not what have you done to it to help
Old 06-24-2007, 11:09 AM
LTLHOMER's Avatar
We tried a ton of fan/radiator combos before figuring out that it was something in the tune that was making it run a lot hotter than it should. Wish I would have tried that first but Don Bailey came to the rescue and I was out cruising around all night with no overheating problems after having problems just a week before with no other changes but the tune.
Old 06-24-2007, 01:48 PM
02SSLE's Avatar
so do you guys think I should cut upper radiator support and stand a new radiator up and leave my puller fan on it? Someone has to have had this problem before.
Old 06-24-2007, 03:45 PM
RW99's Avatar
Hey, Darren...
Twin pushers mounted right on the radiator (after AC removal) keep the car reasonably cool even on 95+ degree days... I tested that out a couple of weeks ago. The car got up to about 220 max (aftermarket coolant temp gauge) on a really hot day in stop and go commute traffic. On normal temp days I'll see about 180 degrees whether at speed or in traffic. I use distilled water and water wetter with just a bit of antifreeze. Stock radiator. Oh, and I pulled off the weatherstripping from the underside of the hood (by the window) to allow air to escape there... and the nostrils on my WS6-type hood are cut open (behind the hex mesh).
02ssle, the stock pullers/shroud will move enough air if you can relocate the radiator far enough away from your turbo. What about relocating the AC condenser further forward, or angling it? I don't know how the front skeleton of an SS looks, sorry.
Old 06-24-2007, 05:58 PM
your saying the airflow while your driving isn't the problem. Only when your sitting. So the problem if the fan is coming on, its not pulling enough air across. That black magic fan should be plenty, but you could keep that and add some pushers. What do you have the fans set to come on/go off at at? Doesn't ever hurt to throw in a new thermostat to.
Did dyno Steve tune your car again? If he did then I'm sure its not the tune.
Old 06-24-2007, 09:59 PM
02SSLE's Avatar
yes steve tuned the car I think the fans are set to come on at 185 also I just put new thermostat in friday thinking that might could be it it wasn't.
Old 06-24-2007, 10:06 PM
Darren P's Avatar
Hey, Darren...
so with the AC not much hope
Damn
I am going to re-route the tube from the intercooler to the T/B and put 1/2 of the stock fan back on and see if it will stay cool
it will have the 2 pushers + 1/2 of the stock peice
Quick Reply: Turbo car overheating
