Kenne Bell/D1SC cam difference (For C5)
Old 07-03-2007, 04:08 AM
Z06PSI's Avatar
Default Kenne Bell/D1SC cam difference (For C5)
I have decided to sell the D1SC/A&A FMIC kit and go ahead and buy a Kenne Bell 2.8L for the Z06. The question is how does a screw type blower differ from a centrifugal type blower. I know the screw will build boost lower then the centrifugal but how will cam selection be affected as far as bleed off and power? I had bought a 225/233 .585 115lsa cam and was wondering if I should switch cams? This is a 346 that is going to be driven on the street but would like to get as much as possible out of it and still be driveable. Thanks for any input given.
Old 07-03-2007, 04:20 AM
TT-TECH Veteran
Inspector12's Avatar
Well no one has done extensive testing on the Kennybell setup over here that I have seen, but I would go out on a limb and say I think the cam will work well, but when using the magies I like a strait pattern cam just my preference though. Should be a car with little or no traction LOL!
Old 07-03-2007, 04:26 AM
PREDATOR-Z's Avatar
You are taking a step backwards. D1SC has much more potential for power.
Old 07-03-2007, 06:46 AM
chuntington101's Avatar
i dont know if thats true. the 2.8KB has made over 800rwbhp and over 800lbsft on a 402 ls2! that was with a stock z06 cam and pump fuel!
Chris.
Old 07-03-2007, 08:13 AM
eb02z06's Avatar
Chris.
It's a big step back-that 402 didn't have a z06 cam and the owner pulled the whole motor back out to redo it. FWIW I made 920 rwhp and 820 rwtq out of 347 with a F1R, stock ported heads on pumpgas and meth-oh ans that was at 5900 rpm-ran out fuel. That's more torque than a 402-go figure.
Old 07-03-2007, 08:41 AM
Dumb Ass Vette Moderator
ls1290's Avatar
That cam is pretty big for a 347. It is going to affect the amount of boost made in the entire RPM range. The advantage of going with the KB for lower RPM boost generation will be lessened a bit because of the cam. I feel the KB will be a little better in the lower RPM band ,more in the middle RPM band, and less in the upper RPM band than the D1. Since the car will not be a strip one, the KB might be a little better for you than the D1.
Keith
Old 07-03-2007, 01:35 PM
Drewstein's Avatar
Chris.
I would say it is. Even if the KB put down the 700rwhp I did with my 402 I don't think I would want it at 2K rpm.
I nice linear curve is much easier to handle at these power levels.
Old 07-03-2007, 02:49 PM
mdhmi's Avatar
Out of curiosity, what don't you like about the ProCharger D-1SC?
If you want more bottom-end out of it you could install a smaller supercharger pulley and then run a restrictor plate, or just step up to a 4:10 gear.
Old 07-03-2007, 02:55 PM
Administrator
unit213's Avatar
Say goodbye to any traction that you might've had. You'll have full torque instantly
at WOT across the entire rpm band.
Old 07-03-2007, 03:24 PM
SSilverSSurfer's Avatar
are you looking for more tq? power? or just a different set up?
Old 07-03-2007, 04:19 PM
Jeff@TotalPerformanceEng's Avatar
This is an un-informed statement.
I have owned numerous setups in the same car
P1-SC
D1-SC
F1-R
KB 2.6
KB 2.8H
The HIGHEST hp I have pulled out of my car was with the KB 2.8H.
My cam was a 230/234 585.585 114lsa
Personally, the KB is much more driveable, predictable, and fun to drive.
I wouldnt go back to a centrifugal if you paid me.
Old 07-03-2007, 04:27 PM
Your right, it did not have a Z06 cam in it. It was a 230/234....
Yes, I puled the motor. But it ran and drove. I didnt feel comfortable with the way the motor was built. It was a preventative measure, not a necessity.
Your car was a MAX effort run at high boost (wasnt it like 20psi)
Mine made 855rwtq at 15.5 psi, and a damn near stock fuel system.
We did run it at 18psi, but I had them shut the run down at 4500rpm. We exceeded 875rwtq and the power was still coming on hard. I would have exceeded 900+ if I didnt chicken out.
I have since swapped motor configs. Now I'm running 9.0:1cr, and completely different cam specs. I havent run it yet, so I dont know where it stands.
Old 07-03-2007, 05:28 PM
eb02z06's Avatar
I'm sure it will make gobs of useless power Jeff-I still don't see why anyone needs more than 600 rwhp-we must be a set of crazy folk.
Your right-it was 20 psi but max effort-not-it that was with a 4.13 pulley and a 8 crank so that gives you 67000 blower rpm at 7000 rpm-still shy of the 74000 rated rpm. Also that 920 rwhp was only at 5900 when my fuel system gave out-now that the fuel issue is sorted and Procharger called to inform me my unit should be back next week-we will really get to see what it will do.
This debate can go on and on-i'm biased towards the centri units. Before ditching it i would really take a closer look into seeing what can be done to make more power sooner-it will save you alot of money in the long run.
But in the end the choice is yours.
Old 07-03-2007, 05:58 PM
2002/Black/SS's Avatar
how exactly can u use 800LBS at 2500 rpm on the street? thats only good for a drag setup. id go for the linear power. i wouldnt want to always have to have slicks
Old 07-03-2007, 06:05 PM
Administrator
unit213's Avatar
Easy...a 33" x 10.5W.
I'm with you on this one...traction is going to very difficult to find.
Old 07-03-2007, 06:43 PM
99Z28LS1's Avatar
i would hate to loose to someone because i made too much TQ too fast. and i would also hate to run HUGE tires to get any traction
Old 07-03-2007, 06:58 PM
chriswtx's Avatar
My buddy is running the D1SC/A&A FMIC in his 99' vette. Making 750rwhp at 6000rpm at 14psi running the 3.85" pulley on the standard 6 rib setup and a small 224/228 .581 lift 114LSA cam on his forged 346ci motor. No traction what so ever on the street until the top of third gear...Why would you want to change...
Old 07-03-2007, 10:11 PM
mdhmi's Avatar
Those are some pretty sweet #'s on a 6 rib. Does it hold up at the drag strip? That's usually where I chucked belts with the 6 rib.
Old 07-03-2007, 10:15 PM
chriswtx's Avatar
Its peter pan on the CF. Only chuncked 1 belt in 5K miles of hard driving and that was from a failed water pump. He does alot of weekend back hill runs without problems. Usually 300-400 miles on a Sat. cruise...
Old 07-03-2007, 10:22 PM
Z06PSI's Avatar
Hey Unit what is your traction like on the street and are you ever going to spray that thing?
After driving the Z06 in comparison to the Camaro it just feels more planted then the Camaro did. I am under no illusion however that I will not have traction problems at 600-700 h.p. but maybe I still have a little Cobra envy in me. I almost bought one instead of the Camaro years back and I really like the look and simplicity of the KB setup. Plus my car will go to the track so it can't be all bad.
Quick Reply: Kenne Bell/D1SC cam difference (For C5)
