6.0 truck headers
Old 07-06-2007, 09:41 PM
68LS1WANNABE's Avatar
Default 6.0 truck headers
http://store.summitracing.com/partde...5&autoview=sku
will these headers work under a turbo situation? I'm planning on using the truck manifold setup with a single turbo for my 68 camaro. I'm just wondering if they will support more hp than the original manifolds?
Old 07-06-2007, 10:11 PM
bhz28's Avatar
well I would think the stock 6.0L manifolds would support more due to them being cast, but I could be wrong
Old 07-06-2007, 10:20 PM
LS1NOVA's Avatar
The truck manifolds will not fit with a stock subframe unless you run them upwards and have all the piping close to the hood, which in my opinion is not good. Front mount or rear mount?
Old 07-06-2007, 11:14 PM
Ping King's Avatar
i built a kit in my camaro using truck shorties. Worked great.
Old 07-07-2007, 01:22 AM
ThaBirdMan's Avatar
looks like they would work great
Old 07-07-2007, 06:26 AM
Navy David SS's Avatar
I think stock cast iron 6.0 headers are OK for boost
Let's see $550 for the Summit headers, vice $100 or less for a set of used 6.0 truck headers. Hard decision
David
Old 07-11-2007, 08:26 PM
B18B1LS1's Avatar
my truck manifolds were $6 off ebay
Old 07-15-2007, 09:56 PM
bumpin_records's Avatar
those headers will have to be moddified on the driver side due to the #3 runner hitting the steering shaft.
Old 07-16-2007, 01:12 AM
99NMB's Avatar
the cast manifolds will be stronger, but probably wont flow as good tho..
Old 07-16-2007, 12:45 PM
i paid 200 for my 304 stainless steel headers off ebay very nice welds. just look up headers for a cadillac escalade
Old 07-16-2007, 01:38 PM
jmarsa's Avatar
Why would the Escalade front end be any different than a truck?
--JMarsa
Old 07-16-2007, 01:54 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I think some people are missing the fact that this is for a 1968 Camaro.
Old 07-16-2007, 10:24 PM
oh yeah it is a 68 camaro my badd. 500 though is a lot. like i said i paid 200 for my TRUCK stainless steel headers.
Old 08-23-2007, 12:21 PM
back to the original ? how much power will they hold? will they even make it to 700hp? Just need to know before i spend the dough.
Old 08-23-2007, 06:09 PM
PHIL H's Avatar
Stock 6.0 manifolds will support twice of what you are asking....Ohio boys are running them on their 101mm single.. Car has went 183.7 mph @ 3375lbs.. They are probably at 1400-1500 hp right now...There is more left though..Does that answer your question?
Old 08-23-2007, 09:09 PM
1fstTA's Avatar
I dont want to give away alot of details but they will work and you can get them new for around 300 if you look good enough
Old 08-24-2007, 12:30 AM
frcefed98's Avatar
Hunter02SS has a twin turbo set up with the 6.0 truck manifolds he just put down,
922rwhp and 842rwtq at 18psi!!
Don't think these things won't flow, the ohio boys proved that they support more power then most of us will ever need a LONG time ago.
