No boost + lifters
No boost + lifters
So I notice when my car turns off my lifters all leak down. I suspect they might not ever even get all the way pumped up.
That would defiantly explain why i cant build boost and my car is so damn slow.
And I've noticed my oil pressure is lower than normal too..
What are the odds of having bad lifters? they are the older Comp "R" style.
Originally Posted by Exotic Performance Plus
The low oil pressure is most likely why the lifters are not pumping up. Check the small oil ring, I'll bet is has a cut in it. Bob
so its normal to not really be able to see which ones are up and down when the car is off? I seem to remember being able to see that when it was stock.
Originally Posted by Boostaholic
ok, still dont know if its normal for the lifters to not hold the valves open after the engine is off
just for the record my car stock internals ls1 in the tucson 114* heat less than 20 psi at idle some times. my lifters still keep the valve open.
hmmmmmmm. cant belive the whole lifter batch would be bad. I have seen a lifter go bad on a high mile engine. once I saw i think like three on the same engine. So do all the valves do this ?
if not how many.
if not how many.
I've noticed a few will stay down, have not really done a lot of research on it yet.
It just occurred to me the other day that could be my whole problem not being able to build boost.
