what's everyone using for heads on a single turbo 347?
Old 07-28-2007, 06:42 PM
98SS2836's Avatar
Default what's everyone using for heads on a single turbo 347?
Just as the title states Im trying to lay down some ground info. If any one has some info on cams too?
Old 07-28-2007, 06:53 PM
30th t/a's Avatar
6.0 heads are cheap and easy to find. Basically they flow like a LS6 head but have larger combustion chambers and alot of guys use these with their stock bottom ends to drop the compression down to around 9.5:1, maybe 9.2:1 depending on the head gaskets and if they have the chambers opened up. they usually go for around $300.
Old 07-28-2007, 06:59 PM
98SS2836's Avatar
So ya say a patriot performance lq9 head would be my best bet.
Old 07-28-2007, 07:08 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have AllPro's, but the AFR's work really well and maintain stock locations for all your accessories.
Old 07-28-2007, 07:23 PM
Q8CamaRo's Avatar
+1 i agree, i have hand ported 6.0L heads and they are fine with me
Old 07-28-2007, 07:27 PM
52172's Avatar
looks like your sig shows you have afr heads are you asking for someone else?
Old 07-28-2007, 07:45 PM
RW99's Avatar
AFR 225's 72 cc
Old 07-28-2007, 08:39 PM
nvmy2000ss's Avatar
I would stick with the afr 205's but thats just me. I put down 620rwhp with a very mild cam (224 on a 114) I would think the torque #'s down low would be better. just depends how you drive the car also.
Old 07-29-2007, 06:34 AM
98SS2836's Avatar
My AFR's Are 59cc I would be trying to get the compression down to 9.0 or maybe lower. I can probably do that with a custom piston but its going to be huge money. Unless someone has do it already.
Old 07-29-2007, 08:40 AM
52172's Avatar
You can have the combustion chambers opened up on your afr's.
Old 07-29-2007, 10:00 AM
LS1Tech Sponsor
Slowhawk's Avatar
Sell the 59cc and get the 66's back. You don't want super dish pistons.Of course compression goes around the setup and turbo location.
We prefer the thicker deck heads.Lifted a few 6.0 /Patriot heads while ussing turbo's.
Old 07-29-2007, 10:02 AM
52172's Avatar
why can't he open up the combustion chambers hawk might be easier than selling and buying.
Old 07-29-2007, 01:05 PM
nvmy2000ss's Avatar
Didnt realize they were milled.
Old 08-02-2007, 06:17 PM
grifter757's Avatar
What about LS6 heads for an STS kit how will they work?
Old 08-02-2007, 06:24 PM
SSilverSSurfer's Avatar
im using untouched 317 heads
Old 08-02-2007, 06:57 PM
SPRAYED 01's Avatar
Im using 241 casting heads with bigger valves and many many hours of porting and polishing. Should have flow numbers next week.
Old 08-05-2007, 09:08 AM
98SS2836's Avatar
I think im going to go with trick flows
Old 08-05-2007, 10:08 AM
52172's Avatar
You just made the BEST decision they are the BEST just by a little over the ETP and AFR, but it is noticeable.
Quick Reply: what's everyone using for heads on a single turbo 347?
