423" stroker, Afr 225 heads, F1a Procharger w/front mount.
I already have all of this stuff. I am curious as to which pistons to go to instead of the current ones. I currently have ross pistons in the engine. With 72cc combustion chambers I am at 11.0 to 1 Static Compression Ratio. What would you recommend for pistons and what kind of compression ratio should I shoot for? Also any recommended cam would be most help full. Thanks in advance...
We have had very good results with Diamond pistons and Total Seal rings. Give us a call and Brent can help you out with a piston/ring selection. 260 244-4808.
We shoot for a 9.5/1 compression ratio.
Our blower cam would work very well for your combination.
http://www.exoticperformanceplus.com....html?item=679 Bob
Awesome thanks for the replies. I have read good things about the total seal rings and diamond pistons before. What about bearings? Kings? And any other custom cam that anyone recommends would be awesome. Thanks again
Thanks for the replies guys. Special thanks to bob in his responses as well as offers for service. I will be calling you guys shortly to get those pistons and rings. Also, with a similair setup to mine on 18-20 psi what kind of numbers would I see? I am hoping for 850+ rwhp and gobs of torque. Hopefully this setup will do the trick. Thanks again guys...
Dumb Ass Vette Moderator
Originally Posted by stevegrizzle
I though thermal coated pistons were a "nischt-nischt" for FI ?
Keith
111, 225, 402, 423stroker, afr, compression, f1a, f1r, heads, prochager, procharged, procharger, ratio, recommended, stroker, supercharger
