highest psi on stock springs
Old 08-13-2007, 02:21 PM
quik01ss's Avatar
Default highest psi on stock springs
Search isn't workin but what is the highest boost pressure you can run on your stock ls1 valve springs. I want to try runnin 10psi sometimes but not always.
Old 08-13-2007, 02:48 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
i wouldnt run ANY boost on stock valve springs.
Old 08-13-2007, 02:58 PM
71chevellels1's Avatar
Is there a reason why you want to run stock springs? They make good spring/retainer kits for a few 100 bucks. I also would NOT run boost on stock springs.
Old 08-13-2007, 03:07 PM
LS1Tech Sponsor
Slowhawk's Avatar
Ussually 10lbs is the max on a stock spring setup we run.They can float at any rpm/boost depending on how strong they are. I like Comp 918's if 10lbs + is used.
Old 08-13-2007, 03:33 PM
2000TurboVert's Avatar
Im running 5-6psi and have stock springs... Should I have them replaced?
Old 08-13-2007, 03:35 PM
y2khawk's Avatar
back in the day (~2001) i was at 13 on stock everything
Old 08-13-2007, 03:49 PM
LS1Tech Sponsor
hellbents10's Avatar
Right some seem to be ok. It will be a combination of things, rpm, cam, boost, and how old or strong they were in the first place.
Old 08-13-2007, 04:07 PM
quik01ss's Avatar
Default ..
no..no reason just asking I am lookin to purchase the comp 918's jus wanted to know
Quick Reply: highest psi on stock springs
