Does anyone know if the Procharger F1A fits on the F Body with the Be Cool Radiator?
Does anyone know if the Procharger F1A fits on the F Body with a Be Cool radiator, and a/c condensor in the way? Things are very tight done there with the P1SC as it is. I would like to know if I can gain some space down there by tilting the radiator forward. Enough space to make the F1A fit. Thanks.
8 sec potential, 12 sec slip
Looks like you will have the same setup I will soon have too.
I had this thread bookmarked as a go-by once my F1 gets here.
https://ls1tech.com/forums/forced-induction/735184-pics-my-408-f1r-becool-setup.html
If he can fit it in there with an F1R, we can definitely fit the F1/ F1A no problem IMO
https://ls1tech.com/forums/showthread.php?t=735184
What size motor are you putting the F1 on?
mine runs hot (230ish) with the A/C on and I have the twin intercoolers. I'll bet I know what you are thinking- that the FMIC people taking the plastic part out is hindering the airflow not forcing it thru the radiator after hitting the air dam and going up? While this probably does impede cooling a bit, I bet that the added air coming at it thru the front probably makes up for it. I can also assure you that it will get hot with the A/C on even with that plastic piece installed and twin intercoolers.
