best head studs?
i am blowing out head gaskets at moderate boost and super safe tune, this is on my truck. 5.3 is running strong so far. i have some kind of problem with my set up right now. my first step is a fresh set of head studs but i was thinking about upgrading from the standard arp's.
Originally Posted by speedracer5532
The ARP L19 studs just screw right in, no modifications needed and you torque them to 100 ft-lbs vs the 70 ft-lbs of the regular ARP studs.
Originally Posted by ninetres
Sounds enticing. Is the added price worth it? Do they keep the heads down and the water in better?
Originally Posted by Silverback
I'd be more worried about distorting the block/messing up the ring seal if it wasn't machined with a torque plate at that torque.
Interested in this topic as going to be doing up new motor soon. I will never go past 20psi likely not past 15psi if go for lsx block 427 with afr 225 heads. I am keeping my fast 90 intake at least for now. So will I need these more expensive arp or a1 studs or will the regular arp with gm mls gaskets be enough?
i have taken the basic arp's with cometics to 18psi on the track and 22+psi on the dyno. above 18psi on the track and i start hurting things but i am not sure if my tune is optimized.
lately i can't even do 14psi so it seems i have hurt something or something is worn out.
deck surface perhaps ? head surfaces ? threads in block pulling ? or perhaps the studs themselves ?
block is iron, studs wouldn't pull out of that would they?
can you check the block deck with it in the truck still?
OWN3D BY MY PROF!
I seriously doubt you'd rip a L19 stud out of an iron block. I called ARP a long time ago about them and was going to recommend them to you in your other thread, but was banned. After talking to the ARP guy at the special order shop about them I plan on running them in my new engine. He quoted me $419+ S&H on them if I remember correctly.
OWN3D BY MY PROF!
Originally Posted by Jimmy P
I just ordered a set of the L19's from LME. I believe you can only order the L19 head studs through them, because of certain contracts. Total with ground shipping came out to $521
