Compression Experts-What's comp with stock LS6 heads and -2cc Diamond Pistons 347 LS6
Old 08-31-2007, 12:39 AM
Chicago Crew UnderBoss's Avatar
Default Compression Experts-What's comp with stock LS6 heads and -2cc Diamond Pistons 347 LS6
I am hoping that the compression ratio is 10:5 to 1 (don't ask me why I want so much compression for f/i that's my secret ) but using my bone stock LS6 heads and GM gaskets, what is the exact compression ration on a 347 cubic inch forged LS6 motor using -2cc Diamond Pistons.
Thank for your reply that answers this specific question!
Old 08-31-2007, 01:57 AM
DanZ28's Avatar
I think you hit right on the nose, I come up with 10.5 CR as well.
Assuming you have a 3.905 bore, .055" gasket, pistons are .010" out of the hole like most diamonds are, -2cc reliefs and 64cc combution chambers = 10.5 CR .
If any of my guesses of your setup are wrong let me know and can adjust...
Dan
Old 08-31-2007, 06:07 AM
Dan
Yes,
347 LS6 engine with slightly bigger bore of 3.905 for cleaning up, etc., before being rebuilt, etc.
Old 08-31-2007, 01:25 PM
DanZ28's Avatar
Originally Posted by Chicago Crew UnderBoss
Yes,
Looks like your set then .
Dan
Old 08-31-2007, 01:53 PM
kp
kp's Avatar
if its apart you can have someone open up the chambers a little, I had -2cc wisecos and stock 98 heads opened up to around 67cc and I came up with 9.8:1. Pistons werent that far out of the hole with the stock rods.
Old 08-31-2007, 10:01 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Damn, did you put this in every section?
Old 09-05-2007, 11:28 PM
No, 2 sections, you got a problem with that?
Quick Reply: Compression Experts-What's comp with stock LS6 heads and -2cc Diamond Pistons 347 LS6
