Intake set up for big single turbo?
Old 08-31-2007, 07:25 AM
SUPERBOOST's Avatar
Default Intake set up for big single turbo?
I would like to hear from someone with extensive knowledge or experiance about intakes and throttle bodies for big single turbos,mostly street some strip.Why would you use or not use the following,ls6 with factory type tb,victor jr with elbow or gmpp intake with 90.What are most guys running?
Old 08-31-2007, 07:37 AM
Fireball's Avatar
vic jr with cast elbow here:
http://home.comcast.net/~tfranklin5580/upper_cold_1.jpg
Old 08-31-2007, 09:37 AM
ABeasst's Avatar
I've got a Vic Jr. and Nitro Dave elbow. I got it for better air distribution. Whether or not it makes a difference on my car I dont know because its all I've run.
Old 08-31-2007, 09:56 AM
SUPERBOOST's Avatar
That is one thing I was wondering about is the air distribution,looks like the possibility of going lean on a couple of cylinders would have to be a bad thing on a forced induction set up.I know the ls6 will make more torque at lower rpm's but with a 800-1000 hp how can it make that much difference?
Old 08-31-2007, 10:04 AM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Originally Posted by Fireball
All about the cast elbows!
Old 08-31-2007, 10:12 AM
1fstTA's Avatar
ls7 carb style intake here
Old 08-31-2007, 10:28 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'm running an LS2 intake + NW 90mm TB. One of my advisors does not like how most of the elbows being used (to fit under stock hoods) are so compromised.
Old 08-31-2007, 11:57 AM
SUPERBOOST's Avatar
What about the elbow from intake elbows.com(Arron's)?Would this and a gmpp intake work well for fi,big single,346 with trick flow 225's?If not,what do you recomend for this setup?
Old 08-31-2007, 12:00 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
Just another reason to get a 4" cowl and extend it to the windshield
Old 08-31-2007, 12:01 PM
1fstTA's Avatar
I use a wilson elbow that accepts my 105mm tb I had to cut the cowl off the car but it wasnt a big deal at all. I run the VFN 4in ram air that goes back to the window
Old 08-31-2007, 06:22 PM
SUPERBOOST's Avatar
Can someone add some more info or opinions on this subject? I am trying to deside which set up to go with.I would like to have some more input.
Old 08-31-2007, 07:33 PM
theblur98ss's Avatar
I have the same setup. I'm a little leary of Dave's elbow though. It sure necks down pretty small to fit under the cowl.
Quick Reply: Intake set up for big single turbo?
